Old 12-03-2005, 12:55 AM
CRAZYCRXCOON CRAZYCRXCOON is offline
Exclamation Electrical Problem
Iv got a '88 Crx si with a few performance upgrades(intake,exhaust,cam,pistons.etc......)and ive run into a severe electrical problem. The car starts fine and runs fine until i turn on the headlights, Then the car stalls. Ive taken my alternator and battery to advanced auto parts and both are good. I noticed that my intake pipe was touching the positive battery post so i relocated the battery. Could the Problem be The ignition or coil or a ground?
Old 12-03-2005, 03:10 AM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
sounds like a short. wouldnt be coil cause you said runs fine till switch is flipped on. sounds like short from headlights to ignition.did this happen b4 you relocated battery?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 12-03-2005, 08:52 AM
No The only reason that i relocated the battery was because of the intake pipe.
Old 12-03-2005, 10:45 AM
Smoghog Smoghog is offline
Re: Electrical Problem
WIll the lights work with the engine off? What do they do, are they dim.
Sounds like a grounding prob. to me. Get out the dvom.
SH
Old 12-03-2005, 03:22 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah exactly what smoghog said, do the lights work when the car is off? it sounds like the headlight wiring is grounding somewhere.
Team Lonely Drivers
Old 12-05-2005, 09:14 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
There is a headlight relay on the fender wall near where the OEM intake box would be. Do you have a CAI or short ram intake? You may have gotten the relay wet inside of it or maybe a wire is touching metal. Check it all out and don't be afraid to move the wires around slowly and inspect them with the lights on, etc. Also, check the relay on the other side as well. GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 12-05-2005, 11:23 AM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: Re: Electrical Problem
Just don't ground yourself out in the process... I hate getting shocked...
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 12-30-2005, 09:43 AM
i found it. i had a bad body ground from the battery and a bad alternator ground. thanks for the help everybody peace
