Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 12-03-2005, 01:39 AM
97explorersport 97explorersport is offline
Question Heater Switch
I need to know what the location is of the main tubing for the heater switch. Where does the switch get the suction from to run the other trap doors and vents. There are several tubes on the switch, but it appears that one is for the control and the others are for the various trap doors. Where is the air suppy for the switch Located??? Need help ASAP getting CHILLY here.
Old 12-03-2005, 06:27 PM
jsgold jsgold is offline
The switches are controlled by engine vacuum. Should be a hose running from engine area, just not sure where. If it is not controlling anything you probably have a bad vacuum leak in engine somewhere.
I used to be indecisive, now I am not so sure.
