Old 12-02-2005, 08:55 PM
blktie96ss blktie96ss is offline
Manual Tranny Problems! Please Help
My wifes 93 4.3L 6cyl truck is experiencing a little issue with the manual tranny. The tranny has 168,000 on it and has had no clutch issues to date. However it is not wanting to go into fourth gear. If you shift around the pattern a little something cures itself and then it will go into 4th. Things will be fine and then it will do it again. I have worked on many auto trannys but not real good with manuals. Any insight would be appreciated!
Thanks
Shawn Tillotson
Split Decision Customs
Old 12-03-2005, 03:36 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Manual Tranny Problems! Please Help
Sounds like a shift fork is worn
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-03-2005, 07:42 PM
wafrederick wafrederick is offline
Banned
I have some bad news,replace the whole transmission.GM does not make any parts for that one.The old one has to be sent in and a new in it's place.My father called for parts for one of them once from the dealer and no parts listed for that one.
Old 12-03-2005, 10:27 PM
tRustyK5 tRustyK5 is offline
Dealers are wankers, and lousy places to get parts (mostly)
Check here for NV3500 parts...
http://www.rsgear.com/NV3500trans.htm
And another source here...
http://www.midwesttruck.com/TrancatPDF/NV3500.pdf
The unfortunate part is that you can't just remove a top cover to work on this particular tranny. The earlier Getrag is the same way...integral bellhousing, all aluminum case etc etc.
I'd suspect a retainer pin sheared on the 3-4 shift fork. Do all the other gears operate correctly?
Rene
Old 12-04-2005, 04:56 AM
Rene
Sometimes it acts up downshifting to second or first gear. I really noticed it when it got very cold this past morning. Once she warmed up it got better. Want to change the fluid since it is original, but can not find any specs. on what type it takes.
Old 12-05-2005, 08:01 AM
chevrock22's Avatar
chevrock22 chevrock22 is offline
Re: Re: Manual Tranny Problems! Please Help
In manual trannys you should not have to change the fluid.
Old 12-05-2005, 11:32 AM
79403ta 79403ta is offline
manual tranny
Its basically gear oil (GL 5) and it is good to change it it sure wont hurt it to be changed that way you can drain some of the fine shavings out (normal wear on the gears)
Old 12-06-2005, 07:32 PM
Re: manual tranny
You just need to be sure it doesn't require 'syntorq' like the NV4500 does. If it requires syntorq and you put in regular 80W90 gear lube it'll mess up the syncho's.
Some manual tranny's use ATF too...your owners manual should specify which fluid your tranny needs. It couldn't hurt to change the fluid.
Rene
