Old 06-03-2002, 02:53 AM
ck79 ck79 is offline
Intake Manifold Question
Will the intake manifold from a SOHC VTEC '92-95 be compatible on a 1988 CRX SI head?
My Project CRX is currently running a ZC Block and a SI SOHC head hybrid. However the intake manifold runs the original DX
dual point inject. So to save cash, I have a SOHC/ Vtec intake manifold
system on hand.
Can I just take this intake manifold and use it to replace the DX system?
I know I have to change the wiring for the additional injectors.
So far I know I need the resistor box.
Do I need a different ECU and does the distributor have to be changed as well? I'm not sure if the distributor is for the DX or SI.
Please let me know what parts I need to change or add to make this swap work.
Old 06-03-2002, 07:40 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
yeah..it'll bolt up just fine...you'll want (need) an si ecu as well as the distributor...and the resistor box, like you said.
that's an interesting head/block combo... how's it running?
SOLD!
