Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-02-2005, 06:19 PM
79Monty 79Monty is offline
swapped out engine
I had a machanic put a 2000 4cy engine in a 1996 ford contour GL. The engine runs great but it will not hold a battery charge overnight. Also in drive mode the hazard indicator clicks without prompting. Any help will be appreciated.
Old 12-02-2005, 09:32 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
something is definetely installed incorrect and is shorting causing the battery to drain overnight. Id check all your grounds.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-11-2005, 05:36 PM
Re: swapped out engine
I am looking at three wires coming from the alternator, one white, one yellow and one brown. how do i identify the hot from ground or what should the hook up be. the battery is still draining. thanks in advance for any help.
Old 12-11-2005, 06:06 PM
Re: Re: swapped out engine
there should be a big red wire in there somewhere...has a rubber boot that goes over the nut.
"The CEG Nazi"
www.contour.org
