Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-02-2005, 05:10 PM
harleymotorman harleymotorman is offline
Question fuel pump replacement
I have 91 thunderbird. Ran find then one day refused to fire. I have checked spark and looked at shut off switch and it is depressed. Could a fuel pump just die without any warning. If it is the fuel pump is there any way to get to it without droping tank?
Old 12-02-2005, 10:58 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: fuel pump replacement
Yes, you should cut thru your floor borad
but it would be a whole lot safer to drop your gasoline tank.
Old 12-03-2005, 10:32 AM
could I just put an inline electric pump?
Old 12-03-2005, 12:46 PM
97Bird's Avatar
97Bird 97Bird is offline
Droppong the tank isn't hard to do unless you have a full tank of gas in it! Did you check for voltage on both sides of the switch and at the pump connector?
The Original 97Bird
