Old 12-02-2005, 05:09 PM
cyberinfo cyberinfo is offline
How to Open door Panel in 2002 Windstar
Hello Everyone,
Last night my passenger side door window didn't roll back up. Actually it does goes up but the Glass is going over to the lining on side view mirror end. I was trying to open the door panel to fix it but I couldn't. I have found two screws under door handle from inside. Did open those but didn't help in moving any part of the panel. Is there a better way to open the door panel?
Please help. Thanks for your time.
Old 12-02-2005, 05:39 PM
frostie frostie is offline
Re: How to Open door Panel in 2002 Windstar
I'm going from memory, but you need to:
- remove the door pull (2 screws)
- pop off the black plastic triangle by the side mirror and remove the screw
- carefully pry the door panel away from the door. There are several clips (don't break them). You can buy a special tool to do it (about $2) or just pull.
Old 12-02-2005, 06:29 PM
jaydadder jaydadder is offline
Originally Posted by cyberinfo
Hello Everyone,
Hello,
If your 2002 is anything like my 2000. it doesn't use the old plastic push pins. Undo screws holding door handle or pull and screws along the bottom of the panel, then push panel straight up until it disengages from door. There are hooks molded into door panel and corresponding holes in door.
Old 12-02-2005, 06:40 PM
wiswind wiswind is offline
I have step by step pictures on how to remove the panel from the inside of the door.
They are from my '96.....maybe yours is close enough to the pictures.
http://community.webshots.com/album/201931518cScpNK
Old 12-03-2005, 06:45 AM
Hey Great guys,
It is too cold out side but I will go and try your tips today and let you know.
Thanks a lot for your help.
Have a Wondeful Day,
