Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 12-02-2005, 10:09 AM
gtarman gtarman is offline
2002 325i
Service engine comes on from time to time. Diagnostics indicate thermastat and cam sensor needed. Car will stall sometime but restarts immediatly. Repair shop says cam sensor can cause stalling, also car does not overheat. opinions please.
Old 12-02-2005, 01:31 PM
daniel 61 daniel 61 is offline
Re: 2002 325i
Did you notice, since it happened if the warming time of the engine (reaching normal temp.) take much longer as usual ? If yes you need a new thermostat(stacked open), usually it throws an error code P1624 ,for faulty thermostat.
Old 12-02-2005, 02:03 PM
Re: Re: 2002 325i
OK, that makes sense about the thermastat, it does take longer for the warming time. What is your opinion about the car stalling, it will die on takeoff and then you can restart with no problem. This doesnt happen all that frequently but is annoying.
Old 12-02-2005, 02:34 PM
Re: Re: Re: 2002 325i
I think they are right, you need also a new Camshaft Position sensor- error code P0164, that what they got after scannig,typical symptom(stalling), when it is faulty. It is gonna cost you for both parts(thermostat+sensor) couple of hundred bucks plus labour.
Old 12-02-2005, 03:47 PM
Re: Re: Re: Re: 2002 325i
Thanks
Old 12-05-2005, 02:25 PM
Is the thermastat part Transmission or Housing and the cam shaft position sensor,exhaust or intake? thanks
Old 12-05-2005, 02:39 PM
Re: Re: Re: Re: Re: 2002 325i
Most cases is exhaust which fails, but I do not know, you have to scan for codes. What do you mean transmission thermostat? I do not get it!you need a new thermostat!
Old 12-05-2005, 02:48 PM
Re: Re: Re: Re: Re: Re: 2002 325i
ok, I have been checking on the cost of parts and was asked if it was a transmission or housing, didnt make sense to me either, however it appears repair shops in my area try to take advantage of the consumer.
Thanks
