Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-02-2005, 09:46 AM
ebtdm ebtdm is offline
Turn signal / headlight
I have a '98 civic ex coupe with a problem.
SYMPTOM: When the headlights are on, then the right turn signal when used comes on and stays lit, does not flash. Headlights off the turn signal works just fine. Aditional symtom is the right headl is dimmer than the left.
ACTIONS: I know that both the headlight and turn signal switch are the same module (left side of stearing column), and I have replaced that without affecting the symptom.
I have looked for a possible relay but can not find one.
QUESTION: What and Where would this problem be?
Old 12-02-2005, 01:27 PM
HontegraGSI HontegraGSI is offline
Re: Turn signal / headlight
Have you changed your taillights lately? check if your taillight wires is connected. One time i forgot to connect mine and my signal light stayed on.
95 Integra GSR (4 sale)
89 CRX Si B16a (Sold)
98 Civic eK
Old 12-04-2005, 08:12 PM
mpumas mpumas is offline
Sounds like a bad ground on the right front side of your car. Because the head light and turn signal light is not seeing a good ground, the turn signal will not see a load sufficient to open the turn signal blinker contacts.
Old 12-06-2005, 07:10 AM
Re: Re: Turn signal / headlight
Thanks, I will try both suggestions this weekend.
Old 12-19-2005, 07:50 AM
mpumas hit it right on.
Ground wire on the right front side of car was loose, just like stated.
Thanks a lot to all who responded here and with private messages.
EBTDM
