Old 12-02-2005, 08:01 AM
Xbox2202 Xbox2202 is offline
Send a message via ICQ to Xbox2202
Door problem
Ok, winter has taken it's toll on my doors. My driver's side door has been messed up since I got the car, but the passenger side did the same thing this morning. My door skins are coming off my doors. When I tried to get in my car this morning the driver side almost came off so I went to the passenger side to get in the car, and the passenger side is starting to do the same thing. Is there anyway that I can buy something at Advance or somewhere like superglue to keep the skins attached to the door?
1994 Camaro V6 A4 - RIP 3/1/06
http://www.cardomain.com/memberpage/805164
1994 Camaro Z28 A4 - Bought 4/6/06
Old 12-02-2005, 08:12 AM
goldz28's Avatar
goldz28 goldz28 is offline
Re: Door problem
Skins? Are you talking about door panels? If it is the panel there is a spray glue that works pretty well. If there is a upholstery shot in your town they should have it. Its not to expensive and should take care of it I have used it on the head liner.
Old 12-02-2005, 09:10 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Door problem
3m super 77 available at crafts suppliers too.
that or in extreme cases loc-tite cement.
Old 12-02-2005, 12:44 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Door problem
If your talking about the door skin on the outside your screwed. Need new doors then.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 12-02-2005, 05:50 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Door problem
um thats weird usally door skins have the lip around the edge beaten around the door frame
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 12-05-2005, 07:19 AM
Re: Door problem
I took it to the body shop that's beside my school and they told me that it happens from time to time. I'm pretty sure that it isn't beaten around the door because my passenger side is starting to do it too and there hasn't been any damage to that side.
Old 12-05-2005, 07:21 AM
Re: Door problem
I would have the body shop fix it but the previous owner tried to fiberglass the door back together and it would cost 150 to get them to grind the fiberglass down and fix it the right way with professional grade stuff to keep the door together.
Old 12-05-2005, 08:56 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
so it will cost 150 plus the job or 150 for everything?
Old 12-05-2005, 10:38 AM
goldz28's Avatar
Re: Door problem
Wow the out side of the door is coming off, never heard of that happening before. Good luck with that man, SUCK big time
Old 12-05-2005, 01:55 PM
flatlander757 flatlander757 is offline
Send a message via AIM to flatlander757
I HAVE THE SOLUTION!!!
This was one of the small problems with my car when I bought it, I ended up using some epoxy stuff that my dad had in his shop(I'll go find out the name later for you!). I had tried it twice and it came off both times, then the last time I made sure to spread that stuff EVERYWHERE I could lol.
1. Get some sandpaper and scratch up the surface of the panels where they will touch each other, make sure to blow out the dust and crap after that.
2. Get the epoxy and apply it with something like a small nail file. Very important: You cannot use enough of it Put as much on there as you conceivably can. Make sure to spread it all the way from the top to as far down as possible.
3. Get about 3 clamps(with rubber ends) and use them to hold the panel to the door itself. You'll see where to do this when you see the little lip on the inside. I used a towel to cussion the door's paint from the clamps as extra precation.
4. I did that at about 10:00am and didn't take anyhting off until about 10:00pm... Then I pushed the door shut(NOT slam... keep your hands to push until it latches!) and let it sit overnight.
I did this back in August and it has held strong since then. It is on there solid.
Any questions just shoot!
-Tony- Sold my Z28 looong ago. Now sporting an '03 TJ.
Old 12-06-2005, 07:33 AM
Re: Door problem
It would cost 150 for everything if I took it to the shop.
Anyway, if you can find out the name of that epoxy stuff that would be great. The door hasn't come completely off yet, just about 3/4 of the way down the end and 2/3 across the top. I'm having a hard time with this now since it's so freakin cold outside.
Old 12-06-2005, 10:49 AM
wrightz28's Avatar
Re: Door problem
JB kwick weld?
Old 12-06-2005, 09:37 PM
JB Weld was what I tried the first time, didn't hold.
I unfortunately could not find it because when I used it I think it was nearly empty. All I remember was that it came in a predominately white double tube(it's a 2 part epoxy), with black lettering and cap, and purple background in some areas.
I'm sure he got it at Home Depot or Lowes, so maybe check there?
