Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-02-2005, 08:46 AM   #1
Kellymighton
Angry Just died
Well I fixed the tourque converter problem. and when I was driving around last night the van just died in fact I didnt even know it had stalled it just stopped no warning lights nothing. then it wouldnt start at all. I can smell fuel so i am thinking filter does this sound right? there was no sputter before the stall, an like I said I didnt even know it had stalled till I was slowing for no reason. the speddo even stayed working. it is a 3.1. please help me again if you can
Kellymighton is offline   Reply With Quote
Old 12-03-2005, 07:42 PM   #2
MikeZ34
Here's a few things to check. Even though it didn't sputter and you can smell fuel doesn't mean you might not ran out of fuel. Check that first. Next check to see if your getting spark to your spark plugs. Pull off a plug wire and take out the spark plug and put it back into the spark pug wire. Have someone turn over the motor. If your getting spark, you will see and hear it sparking between the spark plug gap. If there is no spark chance is your ignition module control board is bad.This is also know as the coil pack. All you plug wires run to the coil pack and there are 3 coils attached the ignition module control board. Also there is a wire connection that plugs into the back of the board. Make sure that is not loose and in right and check for bad or cracked wires at the connector. A bad wire or not connected right will result in no spark. Now if your getting spark check your fuel pump it could be bad.
MikeZ34 is offline   Reply With Quote
