| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
300zx questions
I am debating buying a 300zx and in my reserch I found that there was very little noticeable difference between the early and late model 300zxs, were there any major changes that I missed and if so what year.
Re: 300zx questions
there were no real big changes between 1990-1996. here is a list of all the minor changes.
http://www.twinturbo.net/ttnetfaq/FA...fferences.html
![]() ZedEx Crew Member #2
what about the variable valve timing that they discontinued in 96? After bolt on tuning how much of a power difference would I be dealing with there? oh and what year did they start making them with variable valve timing? Was the boost the same in every year model?
Re: 300zx questions
the variable valve timing was dropped after 1995 due to emissions and OBDII was introduced, making the 1996 Z the hardest (and sometimes more expensive) to upgrade. also, suppposedly the 1996 makes 20hp less than the previous years, but that is debatable. the boost is the same throughout all the years.
96 arguably makes the same power as the previous models, just has a much different power band making a tad slower.
VVT was on all 1990-1995 300zx's. boost was the same throughout the years. the general consensus is to stay away from the 90's. they seem to have a couple of bugs that nissan fixed in 91. 96's really can only modified to a certain degree, not because of VVT but because of the OBDII ECU. i dont think anybody makes an aftermarket ECU for it which limits the 96's power ability by not being able to adjust the fuel maps, timing, and other necessary things to making safe power. you would almost have to run a stand alone system or swap pre-95 heads and ECU in.
ZedEx Crew Member #4
I guess that the 95+ are out of the question, were there any driveline modifacations over the years?
Re: 300zx questions
you really don't have to worry a whole lot about drivetrain stuff on the z32's... the twin turbo transmission has been known to hold absolutely insane hp's completely stock and the rear diff is damn near indestructable... oh and it's just the 96's you have to worry about... the 95 or 94 would be the best thing to get as there's possibly less wear on the car and everythings a few years newer...
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
Re: 300zx questions
"Early" 300ZX was debuted in 84. This is known as a Z31. The Z31 was produced 84-89. "Late" 300ZX was debuted in 90. This is known as a Z32. The Z32 was produced 90-96 in the US. The differences between the Z31 and Z32 are unable to be contained in one post. You WERE referring to the early Z32, weren't you? Not the early 300ZX...
Who cares what's in your wallet...what's in your garage? ![]() VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31 Hope you can see the tiny pic...AF reduced the size limit! Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
ahhh...i forgot to mention. most people dont know...but there was a driveline change in the run of Z32's.
Nissan redesigned the 5-speed transmission in 97'. same gear ratios but they used newer technology and synchros to make the transmission engage much smoother and it is all around just smoother and more precise. not saying that the earlier models were slouchs or not precise. nissan just took it to the next level. this is a desired new thing for the true Z32 enthusiast that must have the latest and greatest. thought you guys might be intrigued by that little fun fact. it is a general consensus that it is overrated and overpriced unless you have a car with it already. you are better off just to save your money...unless your car is done and you just want to buy something new. ![]() also keep in mind...i DID mean 97'. this was obviously only offered in Japanese Z32's as they stopped production for the US in 96'. but i think if you have a connect you can get the transmission brand new from the factory through a Japanese Nissan Dealer. in which Coz, Z1, mitch, and others do to get theirs...
Re: Re: 300zx questions
Re: 300zx questions
Got ya.
And yea...the Z32 was produced in Japan until 99.
What brands of aftermarket conponents should I be considering for exaust, fuel management, ignition, water injection, innercooler, ECU and possably a turbo swap.
Exhaust wise is pretty simple, most go with Labree or Borla cat-backs, Labree being sold by www.specialtyz.com.
More exhaust work in the form of downpipes is simple as well, the Specialty Z split downpipes ("super-splits" if you want to be up on the current lingo) are considered the best on the market. Test pipes are generally about the same, usually bought from whoever you bought the downpipes and cat-back from. Intercooler is a bit of a debate, but Stillens are generally agreed to be the best as far as side mounts go. They cost a bit more than others and the power differences between any given manufactures isn't that big, it's largely preference. ECU is a toss up between two suppliers, JimWolf and AshSpec ECUs. Each has their detractors, each has their supporters. The AshSpec is newer and cheaper, but has been accused of being lean and is not available for all models of all years. JimWolf's is better established but costs more. Ashspec offers the Zemulator, whichs allows for the complete tuning of all engine criticals like fuel injection, ignition timing, rpm/speed limiters and VTC release. If you plan on doing alot of tuning on a dyno it is your ultimate tool. Water injection kits tend not to be tailored to a specific car but Aquamist has a system that works quite well. Fuel mangement is usually controlled by any of the major brand air/fuel controller manufacturers, Apexi or Blitz. Or if you are getting a full engine management system like the Zemulator it's taken care of by that. Turbos are where you really get into the big debate. Depending on your desired power levels, any number of turbos will work well. There is no agreed upon "correct" turbo for any given car setup. What do you plan on doing with this car?
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo ![]() Warning: Objects in mirror aren't as fast as they thought they were. |
Re: 300zx questions
![]() dont forget fuel inejectors and drivetrain...RPS is recommended for good clutch/flywheel upgrades but there are others that willbe just as competent to handle the job. fuel injectors...the newer style Nismo's or Border kit if your aiming big are the best. do not buy Venom injectors...seems people have nothing but issues with these.
What is the cornering grip on the stock 300ZXs I know it is .90g on the 3000GT and .98g for the Supra, but I cannot find the numbers for the 300zx anywhere, does anybody know?
