Old 12-02-2005, 02:13 AM
skinnednuckles skinnednuckles is offline
Question P0715 trouble code?!? '98 windstar 3.8
checked codes after MIL went on, have a hard P0715 fault. "input/turbine spd sensor A circuit malf." says my actron reader. i think it has to due with the tranny. any insight as to what i can do to correct it? there doesn't seem to be any "sensor" on the trans; that i can tell so far anyway. thanks
Old 12-02-2005, 07:47 PM
wiswind wiswind is offline
Re: P0715 trouble code?!? '98 windstar 3.8
P0715 is a loss of signal from the Turbine Speed Sensor (TSS) aka Transmission Speed Sensor.
You remove the front Left tire....to get to it.
Old 12-03-2005, 01:48 AM
Re: Re: P0715 trouble code?!? '98 windstar 3.8
thanks wiswind---i'll give it a try!
Old 07-05-2007, 03:03 PM
windstr_98 windstr_98 is offline
Hey wiswind,
Can you really get to the TSS (VSS) from the wheel well after tire removal??? I thought you had to at least remove the tranny heat shield (and possibly the exhaust crossover pipe) for access from beneath.
Old 07-05-2007, 04:21 PM
RickMN RickMN is offline
turbine speed sensor is different than vehicle speed sensor. TSS is usually mounted on the driver's side of the tranny.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
