Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-01-2005, 10:36 PM
reliant2 reliant2 is offline
86 suburban heat failing...
86 suburban 350 4bbl 2wd....the heat is not working very well at all.....the defroster works great, the heat out of the floor vents has become way weak....i know that a few years ago there was a bit of an anti-freeze drip coming from somewhere under the dash on the passenger side, but i've had the truck for 3 years now, and it's never dripped again...
any thoughts? is the heater core dying, is something clogged?
thanks
Reliant in our section, this quadrant...
Old 12-01-2005, 11:29 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: 86 suburban heat failing...
Did you have a drip with the air on or not? If it was with the air on, it was more likely to be a stopped up condenser drain tube. If it was without the air on, I'd say it's time for a new heater core, if none of the heater hoses are clogged. Another thing to check would be the thermostat. A good way to check both is to warm up the vehicle and grasp the heater hoses with the engine running. If they are hot, the thermostat is fine, but the heater core may be clogged. If they are just warm, then the thermostat is hanging open, and needs replacing with a good quality, 180 or 195 degree thermostat, depending on the outdoor temp. where you live.
Old 12-02-2005, 08:24 PM
777stickman 777stickman is offline
thanks
Reliant2: ?'s. Is the air out of the defrosters HOT and can you control the heat out of the defroster vents? If the answer is yes to both then it would seem the heater core is OK and the problem is in the distribution of the heated air. I don't know if the '86 had electronic or manual controls for the air distribution. If you've got HOT air coming from the defroster vents and low air flow from the floor vents then you need to look at the distribution system, doors, cables, ducts etc. Let us know!
Old 12-05-2005, 11:47 AM
Old Dave Old Dave is offline
My 86 Suburban was vacuum controlled. Check behind the glove compartment. There is a clip on a door that it bad about breaking and won't allow a vacuum operated door to open or close. (I forget which it is)
1970 GMC 2WD shortbed fleetside
1984 Olds Delta 88 (won't die)
1997 GMC Suburban K1500 W/5.7L Vortec
2000 Dodge Ram 1500 4WD Shortbed Ext. cab
1998 Chevy K2500 W/5.7L Vortec
2002 Harley Custom Chopper
Wife is a late 1951
