Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 12-01-2005, 09:28 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Angry Tire Hunting Trouble...
17x7.5+40 Offset F and 17x8+45 Offset R
That's what I have... my ADVAN's. Now what kind of tires... size should I get??? Keep in mind that this stuff is completely alien to me! I thought about Yokohama Parada 2's but also the Yokohama AVS ES100's... The Parada's are a little cheaper and come in sizes: 205/40WR17, 205/45WR17, and 215/40WR17 only... I don't really have my heart set on these particular tires but would like to stay with Yokohama's.... maybe the ES100's since they seem to have more size options.
Okay... I want to feel in the wheel well without having a big gap and without lowering. HELP!
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 12-01-2005, 09:55 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Tire Hunting Trouble...
225 front 245-255 rear.. at least... but don't get the tires larger than the original stock diameter, will mess up your speedo and slow your acceleration...
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 12-01-2005, 10:32 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
i would personally go with the ES100's. *see 300zxclub.com thread for reasons georgy*
ZedEx Crew Member #2
Old 12-01-2005, 10:45 PM
1viadrft's Avatar
Yuh, I read it... but what tire size?????????????????????????????????????????????? ??????????????????????????????????????????????????
Old 12-01-2005, 11:00 PM
your guess is as good as mine on tire size. i have no clue about that.
Old 12-01-2005, 11:01 PM
1viadrft's Avatar
LoL
Then we shall learn together!
Old 12-01-2005, 11:57 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Front - 225/45?/17
Rear - 245/40/17
the stock N/A wheels are 7.5" wide so stick with the 225mm wide and i bet you will want 45mm sidewall height but i would check on that first.
for the 8" wide you will want 245mm which will give you a wider track but more than likely you will have to go down the a 40mm sidewall height.
this is just assuming from my past experiences and comparisons. post on TT.net. some of theose guys will know exactly what you want and need.
ZedEx Crew Member #4
Old 12-02-2005, 12:33 AM
DeleriousZ's Avatar
yeah, front's would be 225/45/zr17 and the rears would be (if it was me) 275/35/zr17 or a more modest 255/40/zr17...
Old 12-06-2005, 04:34 PM
Hodo Hodo is offline
You could do the math this way. 1 inch equals 25.4mm a 225/40/17 tire is 225mm wide at its widest point and 40% of that from outside edge to inside edge and has a inner rim diamiter of 17inches. So a 225/45/17 would be good for all four tires, or you can go with 225/45/17 (Z rated or better, this includes W rated) on the front then put 235/40/17 on the rear. That should work out pretty good.
As for tire makes, I personally perfer BF-Goodrich G-Force TA KDW, for daily driver/track tires. Or if you are short on funds the BF-Goodrich G-Force TA Sports, they are a bit cheaper but to me have a horrible tracking tendancey. Dunlop makes some wide range of Z rated tires and so does Yoko.
Finaly got pics of my car....... after I washed it of course.
Old 12-06-2005, 06:43 PM
DeleriousZ's Avatar
this is the way i do my math
http://www.miata.net/garage/tirecalc.html
Old 12-06-2005, 07:02 PM
Z Cars Fanatic
Re: Re: Tire Hunting Trouble...
he has 8" wide in the rear...he should go wider than that.
i already did the calculations for you Georgy...
Old 12-06-2005, 09:10 PM
1viadrft's Avatar
225/45/zr17 and 255/40/zr17 then, guys?
Thanks, Jason and Delerious... everyone else!
Old 12-06-2005, 11:14 PM
Z Cars Fanatic
yes and no...
225/45/zr17 and 245/40/zr17
ask the tire place you buy from to be sure...they will know the benefits and such.
Old 12-07-2005, 12:02 AM
DeleriousZ's Avatar
i'm tellin you 255... why not get the extra cmish of width plus 255 sounds way better than a measly 245 lol
Old 12-07-2005, 12:06 AM
Z Cars Fanatic
wont the sidewalls crinkle if they are too wide? i doubt they will even fit on the wheel.
