Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 12-01-2005, 06:44 PM
supercivic86 supercivic86 is offline
Question Clutch pedal won't go down while driving?
I have a 93 wrangler. I'll be driving along and go to push the clutch in and it won't move at all. I took it to a shop and they had it for 4 days looked at it and even drove it around and of coarse it never did it for them.....got it back and two days later it did it again.....now that its getting really cold its doing it alot more....like 2-3 times a week now.....Please help!!! anyone else have this problem?
Old 12-02-2005, 02:59 AM
Re: Clutch pedal won't go down while driving?
come on people ......someone has to have a idea of whats causing this.
Old 12-02-2005, 11:01 AM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
hey ... i'm guessing since its a jeep you've been 4 wheeling... never had that problem but i'm guessing theres water somewhere that keeps freezing.... i dont know if you would call that an educated guess or not but thats all i can offer haha
Old 12-02-2005, 02:32 PM
Ray H Ray H is offline
Im not sure its cold enough in Seattle right now to cause any freezing problems.
What does it feel like when it wont go down? Does it feel like its metal binding or does it feel like say a hard brake pedal? Your clutch is hydraulic. The only linkage is at the pedal and master cylinder and at the tranny bell housing after the clutch actuator and inside the bell housing at the throwout bearing.
Because it seems it only does it while you are driving, I would think its a problem inside the clutch housing with the throwout bearing or clutch disc binding.
Old 12-02-2005, 03:32 PM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
actuailly, if it's like my 93, it has a hydrolic throw out bearing, so the only "metal" linkage is from the pedal to the master cylinder.
there could be debree or something in the system that's stopping the flow of fluid from the master cylinder. or it could be a problem with the linkage under the dash. I'm not sure how to go about doing it, but it might be a good idea to bleed the clutch to see if there's anyting in there.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 12-02-2005, 03:55 PM
Re: Re: Clutch pedal won't go down while driving?
Good call, you are correct. They had an internal actuator up until 94 didnt they. Then they went to an external one.
Old 12-05-2005, 09:23 PM
Well, it just feels like its stuck.....like its caught on something....if it was something with the hydrolics it would still probably give a little but i have tried with both feet to and it still didn't budge.....but doesn't make any sence....when it does it, i just wait about 5 mins and its fine again. if something was binding up the linkages it wouldn't fix itself in 5 mins....i will take it back to the shop and have them check the whole thing....thanks for the help i'll keep ya posted
Old 03-01-2006, 12:56 PM
ghar ghar is offline
Hi, hey I also have a 93 and its also starting to do the clutch just wont go in when Im driving along. It started on Friday and then was fne all week-end and then did it again yesterday. So was going to take it somewhere to check it out - did you find out what was causing it?
Old 03-18-2006, 11:23 AM
cruizer cruizer is offline
I had the excact problem you are having on my 92. Problem is in the clutch master cylinder. Plastic master cylinders. Wears a groove at the top of the pedal stroke and gets caught. Very hard pedal. Replace it. It will fix your problem, but bleed the system after.
Old 10-30-2009, 05:10 PM
tashwick tashwick is offline
I'm glad I found this page. I have 95 Jeep Wrangler and I am having this same problem. And I don't go four wheeling I don't know what the problem is. I went in for a routine oil change, and it came out getting stuck.. I don't know what to do.
Old 10-31-2009, 10:43 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Welcome to AF.
The next time it's stuck, loosen the bleeder screw on the slave cylinder. Then step on the clutch pedal. If the pedal moves (and some fluid should come out, too) you know the problem is in the slave cylinder or the clutch itself.
If the pedal is still stuck, then the master cylinder is at fault.
