Old 12-01-2005, 05:58 PM
familytyes05 familytyes05 is offline
Question hesitation at high boost...
I have a 94 3kgt and at high boost I have a really bad hesitation and I can't figure it out. Turbos both are fine... changed plugs (did use ac delco dbl plat though.) and wires aren't very old. I recently had a coil crack and I replaced it. the car sat for about 8 months and ran fine before I just can't seem to get this bug out of it! I've ran 3 injector/ fuel system cleaners through it, and I am due for an oil change. I'll try that next, but please any oferrings on similar problems and SOLUTIONS would be greatly appreciated. Thanx
Old 12-01-2005, 06:08 PM
MahdiVR-4 MahdiVR-4 is offline
Re: hesitation at high boost...
Need new spark plugs and gap them down to .32-.34 and get some NGK and might want to try to get 1step colder plugs.
good luck
mahdi
1997 Mitsubishi 3000GT VR4 Twin Turbo SOLD
Greddy Profec B II boost controller set at 14psi, Greddy Turbo Timer, Stillen downpipe, Turbo XS RFL BOV, Walbro 341 Fuel Pump, intake, ACT Heavy Duty Street Clutch, AutoMeter boost and A/F gauge, AutoMeter gauge pod, Viper Alarm System, 15% Tint, 18x9 Saleen Wheelz, Bluethunder sparkplug wire.
best track time 13.068
www.goldenhomes.org -->
Old 12-01-2005, 06:26 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
I would deff put copper plugs in there. Define "hi boost"
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-01-2005, 07:24 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
any wooshing/ wistling noises... maybe a leaky BOV or a boostleak??
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 12-02-2005, 09:22 AM
Igovert500's Avatar
blue + red light magnet
you are getting spark blowout, switch to copper plugs and gap them lower as was said.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-04-2005, 04:41 PM
high boost = anything above 7 lbs.... What do you mean by copper plugs?
Old 12-04-2005, 06:34 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
a copper plug is a plug whose tip is copper. there are also platinum plugs and iridium plugs. but copper are the best for the boost application...and coincidentily coppers are the cheapest. (i'm talking about NGK plugs here).
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-05-2005, 04:15 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
are you using a boost controller?
Old 12-05-2005, 05:52 PM
I think i have these and they work great.
http://www.importpoweronline.com/cat...oducts_id=1713
(you can also can get it from Orielly's if you dont want to wait)
mahdi
