Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-01-2005, 05:23 PM
AccordCoupe666 AccordCoupe666 is offline
Send a message via AIM to AccordCoupe666
will intake pass smog test?
I need to get my car smogged "tested" to get my new stickers from the DMV. I got a shortram intake since then and was wondering will that effect my smog test and maybe cause it to fail??? Cause honestly I believe if i had my stock intake it would pass, but with the new shortram intake...will it make me fail the smog test? someone please let me know. And by the way nothing else is modified under the hood except for the shortram intake.
Old 12-01-2005, 08:16 PM
peacexisxfree peacexisxfree is offline
Re: will intake pass smog test?
yes, it will cause you to fail. you will fail the visual inspection before the tech even beginsm anything. put the stock airbox on, and hook up all the original vacuum lines. nothing can be tampered with. especially the egr.
Old 12-06-2005, 12:28 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
you will pass. CA does not have a visual inspection that i am aware of (they didn't inspect mine). numbers come out the same and i have CAI. don't worry about it.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 12-08-2005, 09:01 PM
Re: Re: will intake pass smog test?
the op already knows that it WILL make you fail. there IS a visual test in ca, why are you supplying this kid and others with the wrong info?
Old 12-08-2005, 09:22 PM
yep, def, a visual test. luckly i put the stock box on. thanks for the heads-up peacexisxfree.
Old 12-09-2005, 02:43 PM
V T E C H's Avatar
V T E C H V T E C H is offline
Wow, that sucks. They are hardcore in CA.
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 12-09-2005, 03:43 PM
asdfbeau asdfbeau is offline
wrong?
uhh, I have an SRI on my civic and it passed smog...I didn't even mention it to the guys testing it and I passed
I also took my car to the DMV and had a visual test; got my registration, no problem. This was about a year ago, but I doubt anything's changed since then.
Your SRI should have come with some CARB exemption info, and my sri has the exemption number right on it.
I live in California as well.
