Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 12-01-2005, 04:16 PM
kij2 kij2 is offline
Unhappy Car stalls on its own, seems like the power trail is in trouble... PLEASE HELP
First the car started to act like it wanted to stall when I would slow down pretty fast, as if the gears weren't shifting down fast enough. Now it stalls on its own sometimes. And it revs up on certain gears without the car actually accelerating. I don't know whats wrong but I need some help.
The car is a Hyundai Sonata 1997.
Thanks
Old 12-01-2005, 11:11 PM
178kgoingstrong 178kgoingstrong is offline
Re: Car stalls on its own, seems like the power trail is in trouble... PLEASE HELP
Thanks
I also have a 1997, SE v6 with 178k miles.
I had the same experience with the rumbling and near stall (it never actually did stall) when decelerating abruptly. It a few weeks it became difficult to take off at a stoplight as I started having stammering upon acceleration. I had to replace my Air flow meter (combo with the MAF sensor and IAT sensor). It helped the hesitation and the decelerating shudder. If you aren't throwing any codes, it is hard to say. A second guess would be the TPS. Since that part has a direct impact on the gas load and directly relates to throttle it also controls the way your car shifts. Wrong timing and idle will produce irratic shifting including slipping or early engagement, too high or too low RPM. Mine lasted 178k, but RIP as of last week.
I did have strange occurances in my gauges but they were directed more to the speedometer. It would fall to zero and spike back up to 70-but not directly with the RPM. I also noticed when they adjusted the throttle too high, I had an awful 2-1 downshift clunk. After installing the TPS, and readjusting the idle, she shifted like she was 3 and no longer 8 and the clunk disappeared!
Usually a stammering is too much air in the a/f mixture. I would start with the easy inexpensive parts, air filter, pcv valve, salvage yard air meter (65.00 vs 438.00 new from dealer). If you haven't had the timing belt done, it would be a good thing to do it now. Have your TPS and Air Metering system looked at. Let us know what happens!
Old 12-02-2005, 12:08 PM
Re: Re: Car stalls on its own, seems like the power trail is in trouble... PLEASE HEL
Thanks for the details, I will send it in to the deaership ASAP and I will have them look at it. I will tell you what happens.
Old 12-03-2005, 10:30 PM
MXlonerider's Avatar
MXlonerider MXlonerider is offline
Send a message via AIM to MXlonerider Send a message via MSN to MXlonerider Send a message via Yahoo to MXlonerider
You describe it revving without actually accelerating in certain gears and not wanting to downshift quickly enough, so I doubt that it's a TPS or air/fuel mixture problem. Start with the simple stuff, yea, be sure to check your transmission fluid. Other than that, sounds some type of a transmission sensor/computer problem.
Check out and rate my vehicles at My CarDomain
2000 Dodge Dakota, 4.7L V8 Auto 4x4 Club Cab Beauty
2002 Hyundai Sonata, I4 5 speed (Gone)
1988 Dodge D100 Pickup, 3.9L V6 Auto (Gone)
Old 12-12-2005, 11:11 AM
quickywd01 quickywd01 is offline
Re: Re: Re: Car stalls on its own, seems like the power trail is in trouble... PLEASE HEL
Thanks for the update.
Nissan, Subi, Yoter, Ford
