Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
View Poll Results: What should I do?
Previous Problem, Fix it yourself 0 0%
Sears Problem, Have Sears Reimburse 5 100.00%
Voters: 5. You may not vote on this poll
Old 12-01-2005, 02:26 PM
kjanowski kjanowski is offline
Angry 00 Bonny SSEi (ABS, TCS & Stability System)
Hi - I had all 4 of my tires replaced, balanced, a front end alignment, replaced shocks/struts and those air bag thingies... at Sears... and when I went to drive my car home, my system notification came on and said to Service Stability System, I seen that my ABS light is on and my traction control doesn't work. Has this happened to anyone else? Do you think Sears could have busted a wire or something? Do you think they should be liable for getting this fixed since this was never a problem I had before I took it in?
Old 12-25-2005, 02:48 PM
kalafre kalafre is offline
Re: 00 Bonny SSEi (ABS, TCS & Stability System)
Did they put the right size tires on?
Old 12-28-2005, 02:58 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
When you said "air bag thingies", did you mean ABS sensor? The problem causing the lights to come on is with one of the wheel speed sensors. If Sears used an impact wrench while replacing your tires, there's a good chance they ruined one or more of your wheel speed sensors(part of the hub bearing), and owe you
