ok i got some new tweeters but my wires from the old ones are dead....could this just be a fuse...or do you think that there could be a break..cus both tweeters dont work
Re: tweeters
did u test them with a multi-meter -when the radio was on? also - make sure ur settin isnt off for the front speakers - lol soounds dumb but.. hey - the radio might just be playin to the back speakers
Re: tweeters
Once you have confirmed that you are not getting any power to the speakers, then next check all fuses that deal with the speakers. Refer to your owner's manual to see which ones there are as i dont have them off the top of my head. If your fuses look good, then you will need to start just follow your wires to check if there is a short or disconnection in them, and follow them all the way to the other end to make sure they are connected properly to the head unit. This should solve your problem.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: tweeters
i just said fuck it and ran them off of my door speakers...whats funny is that i noticed my battery gauge went from a normal 12v to 13v is that odd?
Re: Re: tweeters
most aftermarket installs will wire the tweets to the door speakers... and if i remember correctly from splicing/installing my deck, they share the SAME COLOR wires too so they might have been internally bridged on the stock amps. it's totally okay to wire them together. I dont really think you should notice any voltage differences from this unless you're running a big system (like 700+ watts) and even then it deffinitely wont be an INCREASE in voltage. my thoughts on the increase: during your install your doors were open, which kept the dome light on and slowly drained just a bit of battery life and after you started the car again it charged it back to 13-14volts anybody can feel free to add. i'm not a professionaly by any means and very well could be wrong.
