Old 12-01-2005, 11:52 AM
CRAWFM CRAWFM is offline
failed emissions test
1991,crx,hf.
it failed emissions testing. low idle numbers are just a little out of specs.
any suggestions on how to make it pass ?
Old 12-01-2005, 12:24 PM
Gohan Ryu Gohan Ryu is offline
Re: failed emissions test
Heat up the catalytic converter right before you test. Take it for a long highway run to make everything hot as it can be, and keep revving the engine while you are waiting to test to keep it hot (if the guy doing the test will let you rev up in front of the testing station - heating up the cat isn't allowed and if an inspector caught him allowing people to rev up he'd probably be fined).
The hotter the cat is the cleaner your exhaust will burn.
Old 12-01-2005, 02:51 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
assuming the idle is low, screw it back up to specs and retard the timing. assuming there are no CELs, take her back in.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-01-2005, 03:27 PM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
i sprayed intake cleaner in mine, change the oil, new plugs, set timing to stock, changed pcv valve and that did it for me.
Oh and changed the O2 sensor.
The Evil Sleeper
