Old 12-01-2005, 10:21 AM
civicdemon91 civicdemon91 is offline
Send a message via AIM to civicdemon91
Exclamation OK b16a swap stopped need help from the best you guyz!
OK whats up guyz i would an i know i should look this up but you guyz are the best at this stuff u guyz have helped alot.
ok here the thing im doin a b16a swap right now got the motor in allready but i went to put the throttle cable on an theres no bracket on the b16a mani what should i do?an also should i switch to a gsr or integra i forgot what year clutch cable?i would really appreciate it you guyz are better then the honda ase mechanics with this stuff
Old 12-01-2005, 11:06 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: OK b16a swap stopped need help from the best you guyz!
My clutch cable hangs free just between the fuel rail electrical wiring and the spark plugs... never a problem... I did have it zip tied to the strut brace for a long time but realized that I could tighten it up more if I left it loose.
Edit: I just noticed you said no bracket for "throttle cable" I don't really have one for it either. I let mine loop smoothly, barely resting the looped part under the strut tower brace. It was kinked for a long time and I wondered my idle was so high... haha... stupid redneck mechanic also wrapped the clutch cable around my strut brace when he did swap. Needless to say, I learned some stuff and went in and smoothed it out myself...
Editx2: Ignore my ignorance. I figured you meant throttle cable slack cuz it seems awfully weird to not have a bracket for your throttle actuator...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 12-01-2005, 02:53 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
i used the 90-93 teg cable. i used place racing's bracket on my old ef b16 setup.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-01-2005, 09:09 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
what throttle cable are you using?
Team Lonely Drivers
Old 12-02-2005, 12:37 AM
the si one
Old 12-02-2005, 12:41 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Re: OK b16a swap stopped need help from the best you guyz!
Get creative with your d series throttle bracket.
Old 12-06-2005, 10:13 PM
4thgenSIR 4thgenSIR is offline
I welded some flat bar into the necessary shape and then bolted that to the b16 mani and attached the d series bracket to it. Works great.
Old 12-06-2005, 10:22 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: Re: Re: OK b16a swap stopped need help from the best you guyz!
thats what i was going to say...you can atleast get 1 bolt in untill you get the right bracket...i wouldnt loop it around anything ...all you need is it to get stuck or kinked...that wouldnt be too good
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 12-07-2005, 06:25 AM
Hybrid1990crx's Avatar
turtle, there is no way in hell you are driving your car without a throttle cable bracket lol.
and dude, the stock clutch cable is FINE, ive done multiple swaps, two of my own, and i always have had no trouble with the stock one.
Old 12-07-2005, 08:05 AM
Come on now...if you mean bracket that holds the actual mechanism that blips throttle on the IM then yes I have one of those. I was talking about the brackets that hold the cable slack.
And yes having the slack kinked does suck a bit.
2010 Honda CR-V EX
Old 12-07-2005, 11:18 AM
turtle, yeah im talking about the bracket that the throttle cable goes go too, right before the TB. No way are you running without one, and if so i want proof!
Old 12-07-2005, 12:35 PM
Of course I have one of those as I already tried to explain.
I may not know all the terms but I'm not that ghetto...
2010 Honda CR-V EX
Old 12-07-2005, 06:21 PM
ohhhh duh on me. sorry lol. when you gonna get new pics of your car, nigguh?
Old 12-08-2005, 08:18 AM
I really need to get a digital cam. Needless to say, winter is not bondo friendly but it's not that bad. From a distance the ghetto painted clear corners, bumper signals and side markers (to amber), sunroof delete, sheet metal/bondo fabricated rear 1/4 panel and refitted stock side skirt (whole car is primered) doesn't look that bad...
for a beater
2010 Honda CR-V EX
Old 12-09-2005, 11:28 AM
allright guyz i appreciate it really u guyz have helped me since the beginnin with my other hatch with the z6 swap an now with my new swap ill have pix of the ride when im done with everything thanx
