Old 12-01-2005, 09:55 AM
bouchez101 bouchez101 is offline
brake pedal goes to floor!!!!!!!!!!!!
working on 1996 caravan right rear wheel cylinder blown fluid all over tire checked reservoir it was empty - filled reservoir drove to my house replaced cylinder blead rear brakes got air out still no pedal -can get pedal back with key off when started no pedal back down near floor any ideas ......master.......proportioning or metering valve? pls help thank you
Old 12-01-2005, 02:54 PM
coalminer coalminer is offline
Send a message via Yahoo to coalminer
Re: brake pedal goes to floor!!!!!!!!!!!!
The way the brakes are on the Caravans work, you would need to bleed the left front wheel too, its not both front and both rears like they used to be.
