Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-01-2005, 09:14 AM
JJ052653 JJ052653 is offline
1995 Abs System
Is there a way to disable the ABS system, until I take to a shop to fix ? The ABS system keeps going and off, causing breaking problems and a
safety concern.
Old 12-01-2005, 01:14 PM
maxwedge maxwedge is offline
A990 racer
Re: 1995 Abs System
Remove the relay in the relay box under the hood.
A990 racer
Re: 1995 Abs System
Old 12-01-2005, 01:29 PM
Will the relay be properly mark and also, will this Interfere with normal breaking ?
Old 12-01-2005, 01:54 PM
A990 racer
Re: 1995 Abs System
It should say abs relay on the inside of the cover or on the top, normal braking will be ok.
Old 12-02-2005, 06:23 AM
Re: 1995 Abs System
There were 2 relay switches. ABS PUMP and ABS main. I remvoed the ABS main 30 Amp fuse. this seem to work. Quesions, did I remove the correct fuse, should I removed the ABS pump fuse or should I have removed both ?
Old 12-02-2005, 06:47 PM
A990 racer
Re: 1995 Abs System
You are good to go.
