Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 12-01-2005, 03:15 AM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
GM radiator????
It has come time to replace my radiator, however I noticed the nice little GM stamp on top of the radiator. I've had the truck for about 3 years w/o any cooling problems - until now. Does anyone have any info about this radiator? Possibly cheaper? Or maybe better cooling...Also, just swapped out the water pump, pretty easy job!
WAR UTAH!!
Old 12-01-2005, 07:27 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: GM radiator????
Sounds like you have a replacement radiator, not factory original.
Would be interesting to know the specs on it.
If you have a 22R/E, you can upgrade to a 22RTE (3 row) rad for < $100 from your local TransPro (GoDan radiator) wharehouse.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 12-01-2005, 11:26 PM
KimMG KimMG is offline
AF - Advisor
Re: GM radiator????
Where was your truck manufactured? Some GMs and Toyotas are made on the same line.
Old 12-01-2005, 11:28 PM
AF - Advisor
Re: GM radiator????
Check with your local radiator shop. They may be able to recore your radiator for less than the cost of replacing.
Old 12-02-2005, 05:47 AM
Re: GM radiator????
Yeah, I figured it was not original equipment, however, I will double check where it was assembled. I will tackle this small project this coming weekend. I will also check into re-coring. Thanks for the suggestions and help.
Old 12-08-2005, 03:17 PM
mooseketer mooseketer is offline
GM Radiator in your pickup
Your GM radiator is ORIGINAL equipment. You can get a good radiator at http://www.radiatorbarn.com/ . The GM on is probably not worth rebuilding.
Old 12-09-2005, 02:22 AM
Re: GM radiator????
New radiator has been installed. The GM radiator was shot to hell. Decided to get the 3 core 22rte from NAPA for $140.00. Pretty straightforward install, other than it has been about 5 degrees outside during the day. Thank goodness for my garage. Thanks for the suggestions KimMG and fourwd1.
WAR UTAH!!
