Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 12-01-2005, 01:58 AM
killer_ssn killer_ssn is offline
Question Gas
hey guys
how good is your gas millage on your cars?
i got a 2000 civic SiR and i get 400 km for the tank but when does the gas light go on? i've near empty and no light?
how can i check if it works?
thanx for all the help
Old 12-01-2005, 03:54 PM
vandy97dx vandy97dx is offline
97 DX, dunno if it has same type milage but I can usually push it to 320 miles to a tank. if I wanna be runnin' on fumes. My light usually comes on around 290 miles, depending on how I've been driving also.
Old 12-01-2005, 03:59 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
Re: Gas
The light doesn't come on until you're REALLY empty. I dont think you can check to see if the light works, it should just be one of those things you hope you never have to see. Btw, you shouldn't run your tank almost empty, less than 1/4 full puts stress on the fuel pump.
As for mileage, I have a 2000 non-vtec (DX) and I got 30mpg city (about 12.7 Km/L) average in the summer, I rarely ever used AC though.
Old 12-01-2005, 11:30 PM
GreenGeckoUSA's Avatar
GreenGeckoUSA GreenGeckoUSA is offline
Re: Gas
I have a 98 lx (manual) and I usually get between 36 and 38 mpg. I have a CEL on for the cat and o2 sensor so it has dropped to 33 - 34 mpg. After years of worrying, I'm not bothered with the gas light anymore (it has never come on) I just fill up when I hit 300 in the winter and 350 in the summer.
Old 12-02-2005, 12:21 PM
exman98 exman98 is offline
Re: Gas
98 ex coupe (d16Y8) use recommended octanei am only getting about 26 mpg. i know it is bad. i have changed my fuel filter, ran injector cleaner (fuel additive) keep up on maintenance , changed air filter, have a new oem CAT, and o2 sensor. i have even changed my driving habits i used to get around 30 mpg. this is with no highway driving. i have gotten over 40 mpg with all highway driving!!i think i might need new injectors. i suppose one injector failure can cause this much decrease. i have put the Lucas fuel injector treatment. that bumps me up to about 27-28mpg. what do you guys think.
so you are asking me what should you make? Ummmmm.... well i vote meth lab.....helps out the community and gives people like you a job
I love out driving people.
"what's all those cylinders for anyway"
Old 12-02-2005, 10:33 PM
Thanks for the tip. I'll keep the empty thing in mind. Although, now I'm at 305 to the tank and the light hasn't even come on yet where as sometimes it'll come on at like 285 or so. But i think i'm gonna start ignoring the light too and just filling up when it hits a certain milage. I figured being close to empty could mess up the car, but wasn't exactly sure what it would mess up.
Old 12-03-2005, 12:31 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Re: Gas
SOURCE:
Honda Service News March 2003
TITLE:
Charting the Fuel Gauge and the Low Fuel Indicator
APPLIES TO:
1998-03 Accord, 1996-03 Civic, or 1999-03 Odyssey
SERVICE TIP:
If an owner is leery of the fuel gauge or low fuel indicator accuracy and worries about running out of fuel, you may be able to restore faith in the accuracy of this hardware by charting the operation.
If the fuel gauge, the low fuel indicator, or both doesn't give your customer a warm, fuzzy feeling, don't replace the fuel gauge or the sending unit until you've first charted the fuel gauge needle position and low fuel indicator status. You rarely improve accuracy by replacing fuel gauges and sending units. To chart the fuel gauge needle position and the low fuel indicator status, do this:
1. Have your customer bring in the vehicle when the fuel tank is nearly empty.
2. Drain any remaining fuel from the tank.
3. Park the vehicle on a flat surface, and add 2 gallons of fuel to the tank with the ignition switch turned to LOCK (0).
4. Start the engine, and note the fuel gauge needle position after 2 minutes . Draw a picture of the fuel gauge showing the position of the needle. Also note on your drawing if the low fuel indicator is on or off. Turn the ignition switch to LOCK (0).
5. Add 2 more gallons of fuel to the tank. Start the engine, and note the position of the needle after 2 minutes . Draw another picture of the fuel gauge showing the current position of the needle. Note the status of the low fuel indicator. Turn the ignition switch to LOCK (0).
6. Repeat step 5 until the fuel tank is full. Then give your customer all of the pictures you've drawn. They're usually enough to convince even the staunchest Doubting Thomas.
Old 12-03-2005, 12:33 AM
kris's Avatar
Re: Gas
99' Civic Si, I usually fill up at around 350 to the tank. Most I took it to was 370. Typically fuel light comes on for me around 340ish. The fuel light should come on with around 1.5 gallons left.
Old 12-05-2005, 10:59 PM
Krayzie873 Krayzie873 is offline
Send a message via AIM to Krayzie873
Re: Gas
i have an 00 si. i wondered if my light was broke too so i started to run the gas out. my light finally came on when i hit the E line. i got like 20 sumn miles and it still didnt run out.
