Old 11-30-2005, 11:35 PM
haweater haweater is offline
Question How does one check error codes on a dodge?
In my Honda, you just pull up the floor mat and count the blinks on the LED in the computer.
On my Chev 3/4 ton, there are none, it's a '78 and I love the fact that it has no brain!!!!!!!!!!!!!! Error codes are.. you turn the key, it doesn't start ---> check for spark and check for fuel
How the hell do you ask a 2002 Caravan what's ailing it ?!?!?!
Old 11-30-2005, 11:44 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: How does one check error codes on a dodge?
On the pre-OBDII chrysler vehicles, you just cycle the key 3 times and count CEL flashes, but i don't think you can on the '96 and up vehicles. Just go to autozone and have them scanned for free!
Old 12-01-2005, 06:32 AM
mudpig mudpig is offline
Send a message via AIM to mudpig
:[/quote] I have a 97 voyager and cycling the key from off to on 3 times works for me. As a matter of fact I just got done checking mine.
Old 12-01-2005, 06:41 AM
I found this web site it may help
http://www.allpar.com/fix/codes.html
Old 12-01-2005, 06:54 AM
bigoldchevytoo bigoldchevytoo is offline
Unhappy Re: Re: How does one check error codes on a dodge?
Problem is I live on an island a long way away from an autozone.
Old 12-01-2005, 11:21 PM
Try turning the ignition on and off 3 times. On th 3rd time, leave the ignition in run. Observe the check engine light as it will flash a certain number of times then pause, then another number of times.
Old 12-04-2005, 12:44 AM
vamc's Avatar
vamc vamc is offline
It should show the erroe code where the MI. is. after the 3 key turn cycle. no need to look for the blinks of a light.
Old 12-04-2005, 05:25 AM
vipergg vipergg is offline
You could pull the codes up until they did the last redesign by the keydance method . 2001 on up you cannot, you'll need a scanner .
Old 12-07-2005, 12:04 AM
Actually the key dance thing worked to get codes 1282, 1684 & 1698. Now I just need to figure out what to do with them.
And it's a 2002.
Old 12-07-2005, 01:28 AM
vamc's Avatar
What do you need to know about them?
