Old 11-30-2005, 10:12 PM
clayton04chevy clayton04chevy is offline
Send a message via AIM to clayton04chevy
Tachometer stuck at 6k
I was driving my 04 on the turnpike today (only the 3rd time on the turnpike), and I look down and the tach is stuck at 6,000 RPM's. My temperature and everything is fine. So I get off on my exit, and put it in neutral and it'll go down to about 5800. Is there a fix or can I hit it or will it just fix itself and go away?
2004 Chevy Silverado, 2002 Chevy Camaro Z28
4.8L V8, 5.7L V8 6-speed
Truck-Flowmaster 40 series 3.5" Tips, Car-Magnaflow, Volant CAI
K&N FIPK 77 series
Old 12-01-2005, 06:22 AM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: Tachometer stuck at 6k
Does it return to 0 when shut off?
If not,
See if you can wriggle a thick wire in there and push it back down. Works when the battery gauge gets stuck in a funny spot. May have to remove the faceplate to get a wire in as the tach is pretty far from the button hole.
If so, good luck with that! =P
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 12-01-2005, 06:35 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Is it still under warranty?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
