Go Back   Automotive Forums Car Chat > Ford > Mustang > Non-Performance
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations.
Old 11-30-2005, 09:57 PM
Interstate526's Avatar
Interstate526 Interstate526 is offline
Door Alignment???
I have a 66 that was in a wreck at one point. it wasn't me, it was the previous owner. Anyway, the passenger door is kinda screwed up and out of alignment pretty badly. but it still closes.
does anyone have an idea of about how much it would cost if i took it to a body shop and had them work on it?
"All good things are wild and free"
-Henry David Thoreau
Old 12-15-2005, 02:45 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Door Alignment???
You just might be lucky and only need new hinges for your door! If they're original, I'm pretty sure they'd be worn to the point of the door no longer being aligned properly. Hinges will take a shop no time at all to replace, which means a lesser labor time charge for you! However, if the door itself was damaged from the collision, could be another matter..
Old 02-28-2007, 01:14 AM
smurfmobile smurfmobile is offline
check first to see if there welded or bolted hinges, don't know for sure but i'd say their welded, witch woulnd't be so cheap. also if thier welded try lifting ,pushing down, pushing door open, or closing with a large socket in hinge to bend the hinges, you have to do them seperatly or one toget desired effect.
Old 04-25-2007, 09:30 PM
thanks
