Old 11-30-2005, 10:49 PM
z28trick z28trick is offline
Send a message via AIM to z28trick
lt4 cam questions
im about to purchase a brand new gm performance parts LT4 Hot Cam. i know the idle is rough and that it will throw off the computer. does the LT4 knock module fix that problem? if yes, how much does one cost and where can i get one? also i would like to know if the lift of that cam would work with my stock heads. i have 1.6 roller rockers and i need to know if the cam has too much lift and if it will make the piston hit the valve. also i need to know if 385 fastburn valve springs will work with this cam and whether or not shims are needed. thanks
Old 11-30-2005, 11:18 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: lt4 cam questions
i can answer your knock module question...they are around $35, you can find them online or through a dealer
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 12-01-2005, 10:38 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Well before u spend the money find out how much lift the heads can handle and the valve seat pressure of the springs u have. If the cam has a lot more lift than the one u have get new springs,locks,and retainers to be on the safe side.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
