| Off-Topic Talk about anything other than cars. |
As the title says, the negative camber on my car is ALOT! I already read the whole entire stickie by GSXhooptie but I still have some questions...
I am in bad need of putting a kit on the rear tires (I most likely with Home Depot that mod) But for the front...the camber is not as significant as the rear, but the tires are still wearing much fast on the inner edge compared to the whole tire. Is this Okay? how much negative camber is ok? Also I would rather have the to last as long as possible, would that mean zero camber? Also the rear tires literally look like this: /......\ The rear tires are that bad! The outer edge is pratically brand new and the inner edge is gone...Would the Home Depot mod be alright (since it will be cheaper)! Thansk Any help and info would be great!
Re: HELP with negative camber!
get both kits...you'll be burning up tires like nothing. spend the money on the camber kits and your problems will be solved. once the kits are on, get an alignment and your tires will last as long as they're meant to.
it also depends on what kind of driving you do, if you autocross you'll want to run more negative camber than if you don't.
Dr. Disque - Current cars: 2008 BMW 135i M-Sport 2011 Mazda2 Touring Past cars: 2007 Mazda 6S 5-door MT 1999 Ford Taurus SE Duratec |
Negative camber isn't ok in any circumstance no matter how much its off, any neg. camber will cause the inside of the tire to wear unevenly from the rest, and once a tire is worn on the inside it will continue to wear the same way even if you do get it aligned. So you already have to buy new tires and you have to pay for an alignment on top of that. If your rears are like that how low did you drop the car? Do you have coilovers? I bought a rear camber kit off of the internet, and all it came with is a bunch of washers and a new upper control arm mounting bracket. All I would have had to do it buy washers and I could have fixed the rear camber. So keep that in mind.
Re: Re: HELP with negative camber!
Thanks for the info though!
Re: Re: Re: HELP with negative camber!
on the front you just un-bolt the spring/struts from the strut mounts and install the handy-dandy little adjuster that they send you. the rear was just a set of bushings that moved everything over a little bit, neither were really that though though. |
Thanks gthomson, sounds good!
no problem....let me know how everything turns out.
The HD kit works fine, if you want to use it. Get the alignment afterward. Changing camber changes toe, and toe is a more major issue than camber, afterall. Have fun!
I used to own a DSM. Quote:
