Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-30-2005, 09:41 PM
jpflight120 jpflight120 is offline
Question Nos
I have a 2002 ls v-8 that i want to put Nos into and i was wondering how is this done and if i can just bolt it on or if i need to adjust the fuel system or anything else. All ideas on this if its a good or bad idea please. And if you could give me a website to help me look.
Old 11-30-2005, 10:57 PM
Lead Foot Lead Foot is offline
You could ask this guy. Personally, I don't like N2O. Plus where I live, the police could impound your car if you even have the hoses hooked up to the tank while the car is operational. Who ya tryin' to outrun anyway? J/K
Old 12-02-2005, 09:37 AM
N2o
i just want to know if this will cause any problems with the high compression and all. and i just want to know if im going to have any other problems or what will cause those problems.
Old 12-02-2005, 12:59 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
It really depends what kit you go with.
Btw, nitrous loves high compression.
That aside, from what i understand a dry system is sprayed before the MAF so fuel is accounted since the MAF picks it up. Youll more than likely have to upgrade injectors and I would recommend putting it on a dyno just in case.
A wet kit has fuel mixed in with the nitrous. I believe the Zex kit is a wet kit and has a subinjector to add the extra fuel. I believe a wet kit is safer as well. Either way, put it on a dyno and get it tuned properly. Nitrous is hard to tune for and can be very dangerous for your engine. Spraying at too low of an rpm is a good way to puddle nitrous in the intake and blow something up and bouncing off the rev limiter while spraying is a sure way to bend a rod.
Some other kits like the Venom actually tap into the pcm and injectors and actually increase the pulse of injectors when the nitrous is being sprayed. It also has a linear and drag mode and can be set for rpm and throttle position. It taps into the 02 sensors so if a lean condition is read, it immediately stops the nitrous. Its one of the more advanced nitrous systems as well as safe, but also much more expensive. (~$1200 for a VCN-2000)
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
