Old 11-30-2005, 07:39 PM
kalewine kalewine is offline
1990 Accord door lock issue
Drivers side door latch doesn't work, door is, unfortunately closed. Linkage is fine. I found one at a junkyard, located what seems to be the hole for a tool to manually trip the latch. I sacrificed a small screwdriver and made a sort of tool. No problem with the loose purchased mechanism. The one in the car doesn't even feel like the sliding part is there. Yes, I made sure it was in the unlocked position. It acts as if it is already tripped (the door is not budging at all) or that the lever I am trying to trip is what is broken. Other than sawing the door off,do you have any suggestions?
Old 12-01-2005, 04:37 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 1990 Accord door lock issue
Call a locksmith, ask them if it's something they've seen before. They usually have and know how to deal with it.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-01-2005, 05:32 PM
AccordCodger AccordCodger is offline
Inside latch? Outside? Both?
