Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 11-30-2005, 05:43 PM
toyaco15 toyaco15 is offline
Diff. drop
I have a 98 tacoma 4x4 and i had a 2.5" lift kit from daystar installed on it. I also have kyb shocks... I've noticed when i hit a pot hole or enter any kind of drop off the front end of my truck makes a violent thud that never occured before the lift was put on. I figure since my cv's are at more of an angle, thats probably what is causing it. So, i was wondering if the diff drop would fix this problem or if it could be something else.
Any advice would be appreiciated.
Old 12-03-2005, 11:26 AM
Re: Diff. drop
I figure it out... When i put the spacer on top of the coil spring it force my truck up to create lift. So when this happened i lost about 2 inches of down travel which leaves me with 1 inch to play with since stock down travel is 3.5 inches. The thud probably occurs due to the suspension reaching maximum down travel at high speeds...
Old 12-03-2005, 03:53 PM
Flash75 Flash75 is offline
AF - Advisor
Re: Diff. drop
Thanks for letting us know what caused the problem. It always helps to post what solved a problem, perhaps the information will save someone else some time and frustration.
Clifton
