Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 11-30-2005, 05:42 PM
1caddyman 1caddyman is offline
Question hard to start
i have a 1997 sts and it starts up rough and normally won't start on the 1st try most times will start on the 2nd have changed plugs and wires which didn't help it will also give a pop under the hood if the gas peddle is pressed when this is happing ..if anyone can help me ...THANKS..
Old 12-20-2005, 09:25 PM
Caddytech Caddytech is offline
Re: hard to start
I would check the fuel pressure regulator located under the top engine cover--also if the head gaskets are blown it will do the same thing--due to coolant leaking into cylinders--
