Old 11-30-2005, 04:32 PM
tomd0223 tomd0223 is offline
No tail lights, dash lights
The number 17 fuse blows (20 amp) immediately when I turn the lights on. This controls the parking lights and the dash lights. The headlights work along with the brake lights, the dome light, turn-signals, etc. Can anyone give me an idea where to start?
Old 11-30-2005, 04:46 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: No tail lights, dash lights
You need to look for the short. Hook up a circuit breaker in there and start unpluging and looking around.
Also you might check the cig lighter some are on same circuit.
Tail light Bulbs and license plate lights bulbs can also short. HAS IT GOT A TRAILER LIGHT PLUG ON IT?
MT
MT
Old 11-30-2005, 05:20 PM
Re: Re: No tail lights, dash lights
MT
It doesn't have a trailer plug. Hook a circuit breaker to where?
Old 11-30-2005, 05:49 PM
MT-2500's Avatar
AF - Advisor
In the fuse holder that or where the fuse is blowing.
Also any aftermarket radio. They are hooked to dash lights to.
MT
MT
Old 11-30-2005, 05:58 PM
MT
OK MT, I'll give it a try. I'll let you know. Thanks!!!
Old 12-03-2005, 04:46 AM
Stick89's Avatar
Stick89 Stick89 is offline
Send a message via Yahoo to Stick89
Lights
You did not specify what year,so I'll pass on some info for an 89'...
In the lower left corner of the fuse panel,there is a module.It's called a chime module.It controls:
seat belt BUZZER
lights on BUZZER
key in igtn BUZZER
The module has been known to short out,and since it is wired through the lighting system it will pop the instrument panel fuse...which for some unkknown reason means:
no tail lights
no instrument panel lights.
The module can be removed without any problems.
To remove it,you may have to push the left kick panel in a little to see the release tab.Pull the module,put a new fuse in and you should be good to go.
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
Old 12-05-2005, 05:45 PM
OK MT, I found the problem. It was a short behind an aftermarket radio. One of wires was shorting to ground. It caused my tail lights, front marker lights, license plate light and high mount stop light to all blow the bulbs. And of course the 20 amp fuse was also blowing. Thank God! Thank you for your help. I really appreciate it. Tom
Old 12-05-2005, 05:52 PM
Jeepme Jeepme is offline
Thanks for the heads-up on the chime modual, Stick89. I'll file that away for future reference.
Old 12-05-2005, 05:59 PM
MT-2500's Avatar
AF - Advisor
You are welcome Tom .
We are glad you got it fixed and all is well.
And thanks for letting us know how it went.
MT
MT
