Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-30-2005, 10:07 AM
mr. ck mr. ck is offline
Talking eclipse gst
I have a 1998 eclipse gst with intake, what else can i do
Old 11-30-2005, 11:00 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: eclipse gst
you could probably post in the correct forum. you have a 2G eclipse. you are posting in the 3G eclipse forum. they are two different cars.
but to answer your question...there are tons of things you can do. get a MBC, an aftermarket boost gauge, and turn up the boost.
you can also remove the BCS restrictor. This will allow you to up the boost 1-2psi without problems.
These are the basic things that will allow you to get a little more power for no money. next, upgrade the BOV(make sure that you get a recirculating BOV), and upgrade the exhaust.
the stock fuel system can handle about 15-17psi. the stock turbo(t-25) is effecient to about 17-18psi. if you want to go higher than that, you will need to replace your fuel pump and get bigger injectors. then you swap in a 16G turbo in place of the small ass t-25.(you will need an install kit to upgrade to the 16G).
as you can see, the possibilities are endless.
the most important question is...what do YOU want out of the car? do you want a more peppy daily driver or do you want a track queen? How much WHP do you want out of the car?
Old 11-30-2005, 11:06 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
come over to the 2g forum and read the FAQ
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
