Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-30-2005, 12:58 AM
Dave S. Dave S. is offline
Cool 2003 malibu starts for 1 second, dies. fuel filter??
I suspected some bad gas got in there until I checked the fuel pressure at the schrader valve. 60 psi I can hear the fuel pump run for a second when I turn the ignition on. could it be the ignition module or coil pack? if so, why would it start at all? at least it should be covered under warranty.
Old 11-30-2005, 07:17 AM
steve_o steve_o is offline
Re: 2003 malibu starts for 1 second, dies. fuel filter??
I have seen issues like this related to the IAC Intake Air Controller.
The engine requires an unrestricted amount of air to start. For this the EEC opens the IAB 100%.
As soon as the engine RPM self sustains and begins to stabilize we now need air to Idle
On my '98 V-6, its mounted on the top/side of the throttle body. Air is allowed in from in front of the closed throttle body, and “bypasses” the throttle body plate. The air is then released into the open intake track flowing directly to the cylinders. The whole idea behind this is simply a way for the computer to give air to the engine without needing a driver. The IAB is either open or closed completely.
I have experienced when carbon builds up inside it prevents the little plunger from opening or closing. So I took it off and cleaned the mechanical area (not electrical) with some air intake cleaner and a Q-tip.
Manufacturers suggest replacing for $60 to $90, but my way worked and was cheaper.
Old 11-30-2005, 07:24 AM
Old Lar's Avatar
Old Lar Old Lar is offline
I had a problem with my Buick and it was an ignition resistor. One of those safety devices that prevent the car from being stolen without the correct ignition key. If I recall it was a pricey repair including getting the car towed back to the dealer.
Old 11-30-2005, 09:25 AM
Call off the hounds, Its running!
The theft deterrent system light was blinking. The owners manual said to leave the ignition key on for 10 minutes till it goes out, then turn the key off before starting. viola- it worked.
Now the question is why that happened.... would the wrong key do it? I'm not going to test that theory.
Old 11-30-2005, 09:42 AM
acastleberry's Avatar
acastleberry acastleberry is offline
Re: Re: 2003 malibu starts for 1 second, dies. fuel filter??
This has been a problem for many, many different threads are in this forum on the problem. It's happened to me on a couple of occasions on my '01 model. Last time was about six months ago, no rhyme or reason to when it happens.
Someone has posted that there is a toggle switch to turn off the passive theft system, but I have not confirmed this.
Old 12-08-2005, 09:20 PM
raycorri raycorri is offline
Re: Re: Re: 2003 malibu starts for 1 second, dies. fuel filter??
My security light started coming on again about a year after paying the dealership $450 to replace a faulty Ignition lock cylinder. I was at my wit’s end. My wife and kids would be stuck at night in some shopping center parking lot waiting 10 minutes to reset the stupid thing. I was able to Bypass, Disable or Ghetto Hack my passlock II anti-theft system on my 2002 Oldsmobile Alero without relays or resistors. I had my local Auto wiring tech install a $5 on/off toggle switch under my dash that is connected into the yellow (key resistance/code/recognition) wire that can be cut while the engine is running to essientially bypass passlock I(1) or II(2) permanently.(I do not have nor intend to install a remote starter and I do not have an alarm on this car.) The toggle switch idea came about because of my concern that a dealership tech could possibly reset the security “fail- enable” mode or the battery could die or become disconnected for an extended period of time and reset the intended fault. All I need to do is flip a switch to break the circuit again while the car is running to take the passlock system offline. When the system is offline, the security light is on constantly.(Not flashing.) I don’t mind the light, but others may want to remove the bulb or black it out. Here’s how the setup works:
1)Switch On while engine is running – Security system is on.(Factory Setting) Security light is off. (Circuit is complete.)
2)Switch Off while engine is running – Security system goes into “fail-enable” mode and bypasses the passlock system.. Security light is illuminated.(Circuit is broken.)
3)Switch On while engine is off – Security system is on (Factory Setting)
4)Switch Off while engine is off – Security system detects this as a theft attempt
and will not allow you to start the car until you flip the switch On to complete the circuit.(Acts as a FUEL KILL SWITCH.)
Below you will find a thread and some supporting evidence of why this bypass actually works. The entire job took 25 minutes. There is an incredible link below with high resolution pictures of the wiring for your specific car. I included the actual photos that I used to gain access to my ignition lock cylinder wiring. *Special note: those with GM Class II Data Bus should leave your radio connected during the entire procedure so nothing weird happens. If you are unsure if your car is so equipped, it’s best to leave the radio connected and let it hang. Good luck and post with your success stories! 12/4/05
http://www.the12volt.com/installbay/...694&PN=1&TPN=1 Is this You? Get in your car....try to start it and find that the passlock II is screwed up again, you have to wait 10 minutes for it to reset. When it resets it starts up and runs fine. Fix-------Start the car, find the yellow wire that I'm sure you've read about, the rcode wire that is, and cut it. Shut off the car and you're done! The rcode wire on my 2001 alero is behind and to the left of the radio, you must take out the radio.....the yellow wire accompanies two other wires, the white and black, the 3 wires are alone and run inside what appears to be a cheap electrical tape that will fall apart in your hand when you start tugging on it, they are very thin wires, maybe 18 to 22. I taped off both ends of the yellow wire too.Took me about 14 days to find this out and reading no exageration 1000 posts. Forget all the relay, DEI and resister crap that I'm sure you've read about. All this writing assumes that this will continue to work.....i WILL be back here to post an update if it fails again. If you have doubts of me coming back to update a failure you can email me
http://www.insurorsservicebureau.com...cal/ISB_QA.pdf page 4, The PASS Key Module also has the ability to allow engine operation if it recognizes a system fault in the ignition key reference circuit while the engine is running. In this case the Module enters and remains in a mode which allows the engine to be started and run without reading the resistance chip. This mode requires that the original factory resistance chip key be in the ignition lock
cylinder at the time the fault occurs. During this mode, the
security light will be ON all the time. When the key reference circuit is repaired, the module will automatically reprogram itself to the mode requiring the original resistance chip.
http://www.motorage.com/motorage/dat...09/article.pdf page 3, If the correct key is in the cylinder and that circuit
fails while the engine is running, this is considered a
malfunction, not a theft attempt. The “Security” light
may turn on to warn of a system malfunction, but even if
it doesn’t, a key recognition circuit failure with the proper
key in the lock will cause the TDM to enter what GM
calls a “fail-enable” mode. Essentially, the theft-deterrent
system goes offline and the engine will start and run
with any key that turns the lock.
http://www.directwholesale.net/diagr...4&link=BULLDOG
http://www.directwholesale.net/diagr...7&link=BULLDOG
http://www.bulldogsecurity.com/ and click on vehicle wiring diagrams to select your particular make.
Also how to disable Daytime Running Lamps http://www.lightsout.org/disable.html
2001 Olds Alero Locate the DRL relay in the main fuse box under the hood, it is #22 corresponding to the diagram on the underside of the fuse box cover. Remove the relay, snip pin 87, and re-insert.
