Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-29-2005, 11:10 PM
broseph broseph is offline
newbie in need of help...
i'm really REALLY new to message boards. i am having problems with my '96 civic dx starting. i would like to find the answer to this question by searching the board, but i'm not sure what keywords or phrases to use to find answers. any help you can give me in either finding the answer myself, or help you can directly give me would be greatly appreciated.
Old 11-30-2005, 02:54 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: newbie in need of help...
car has power? car cranks? there is spark? there is fuel? ignition timing set to?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-30-2005, 07:06 PM
car has power, cranks, sparks, fuel, will not start, however will push start.
Replaced distributor, plugs, cap, wires, fuel filter, fuel pump. Could it be the pcv valve? or the fuel pressure regulator?
Old 11-30-2005, 07:13 PM
azroadmonster azroadmonster is offline
is your blinker fluid full? how about your muffler bearings, have they had they're 30k mile check-and-lube? if those bearings fall into the exhaust path, it could get clogged and not allow the car to start.
Old 11-30-2005, 07:17 PM
azroadmonster is a jackass and i don't need his
Old 12-01-2005, 12:00 AM
AF - Advisor
it push starts.....................check the battery voltage and alternator.
Old 12-02-2005, 07:03 PM
the battery and alternator are both good, we did a compression test on it and came to the conclusion that the piston rings are gone. It holds no compression. So to everybody having this problem I would highly suggest a compression test as soon as possible.
Old 12-02-2005, 09:20 PM
AF - Advisor
assuming the engine had low or no compression at all, and cam timing is in spec and camshafts are not broken, then, a push start still would not make it start.
if it had very low or no compression at all, it would not start under any circumstance.
i just found it kinda strange.
anyhow, good luck.
