Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-29-2005, 10:44 PM
ccopriviza ccopriviza is offline
Send a message via AIM to ccopriviza
amp and sub question
how many subs will the amp in the link below run?
and at what watts?
http://www.cardomain.com/item/KIC04KX25001
Old 11-29-2005, 10:46 PM
Re: amp and sub question
if the link doesnt work for you either... its the "kicker KX2500.1 mono amp" on the car domain store page
Old 11-29-2005, 11:55 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Well, it is a 2500watt rms @ 2ohms. So, RMS for a 2 ohm speaker is 2500rms watts...probably close to 4500peak. You can power plenty of speaker with that amp. I would say you cun easily run 3 Kicker 12" L7's off of it. You have to do some math...very easy math. Find out what the RMS!!! (please, peak power doesnt really mean anything) power of what you need to power, and then decide if that amp has enough juice to get the job done. My guess, that amp is way more than you need for as small a car as this is if you actually want to use the system. A good, powerful woofer can do the job just as good as 2 of them in this small car. Get a good, big, PORTED box, and the sound with be awsome. Thats just my opinion. I have a Kicker 12" L7, in a 2.5 cubic foot ported box, powered by a Kenwood 1000watt rms amp, and an awsome head unit. The car beats and sounds fantastic. It isnt all about power, its about placement, and setup. A smaller setup may in fact sound better than a bigger one that isnt put togeather right.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 11-30-2005, 07:13 AM
cficare68's Avatar
cficare68 cficare68 is offline
Yeah I have a 2500w rms amp and I am power 4 perfect 12's on it. I don't even have it turned up all the way at it still hits hard and sounds great.
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
