Old 11-29-2005, 10:43 PM
phess phess is offline
Question Question for them who knows.honda accord 2000.help
I have a 2000 honda accord ex v6.I recently changed the tranny fluid.the lady in the store told me i could use dexronIII and mercon.they didnt have any honda tranny fluid. any ways,my tranny was running good for a whyle untill all of a sudden it started slipping and shifting roughly and it got a little noisy.can this be because of the new fluid i used.can i use this type of fluid on my tranny.anyone.does any one know if this is the right fluid for my transmission.
there is times when it goes back to normal,but not al normal.runs good then bad.good then a little slipping.no sliping ,but no power. sometimes it feels like there is something holding back the car.feels like a heavy load.
Old 11-30-2005, 01:03 AM
mpumas mpumas is offline
Re: Question for them who knows.honda accord 2000.help
Probably not the fluid unless you over filled the tranny. There have been many reports of premature failure of these transmissions. Call American Honda and see if yours qualifies for replacement. They will need your VIN number or you could talk to a Honda dealer.
Old 11-30-2005, 01:04 AM
94 Accord 94 Accord is offline
I'm not sure if it takes dexron II or dexron III on the 2000 Accords. I work at Pepboys and I can find out tomorrow and let you know. I know my 94 Accord says it takes dexron II. I only use Genuine Honada ATF in my 94 Accord. Just like mpumas I heard that some of the 6th gen V6 Accords have transmission problems so that might be it too. There is a recall on some of them or something like that. You should try changing the fluid back to Genuine Honda ATF and make sure the level is correct. Not too low or not overfilled. See what that does. If the problem is still there then take it in to the dealer it might be covered. Goodluck
Old 11-30-2005, 11:18 PM
Re: Re: Question for them who knows.honda accord 2000.help
Hey did you find out about the tranny fluid.thankz for the help homie
Old 11-30-2005, 11:19 PM
Yo man.do u know a website of american honda.or maybe the phone number.please.thankz dog
Old 12-01-2005, 12:58 AM
You can contact Honda at:
http://automobiles.honda.com/
Click on customer relations
Old 12-01-2005, 10:13 AM
lorunner lorunner is offline
Honda DOES NOT recommend the use of any Dextron fluid. They say that it is only to be used if its an emergency and you can drain it and fill it with Honda fluid. The addatives in Dextron -vs- Honda fluid are different and Dextron has been known to cause shifting problems in Honda tranny's. I advise you get it out and replace it with Honda fluid.
Stop asking me about radio codes I cant get them anymore!!!
Old 12-02-2005, 11:59 AM
lorunner-re transmission fluid. Honda doesn't say that the use of Dextron will cause damage to the transmission only that it will causing shifting changes, i.e rougher shifting. So I guess if want smoother shifting, use Honda fluid.
Honda is very stong in their feelings about the power steering fluid though. They say that any fluid other the Hondas' will damage the unit.
Old 12-03-2005, 01:24 AM
Yes thats how my tranny shifs.it shifts roughter ..i think honda fluid does give u smother shifting.i guess ill change it back to honda premium .thankz for the help dog
Old 12-04-2005, 12:18 PM
Actually if you look at the owners manual Honda does say and i qoute
"ATF). If it is not available, you
may use a DEXRONŽ III
automatic transmission fluid as a
temporary replacement. However,
continued use can affect shift
quality. Have the transmission
drained and refilled with Honda
ATF as soon as it is convenient."
So that tells me that they do frown on the use of Dextroon for prolonged periods of time.
