Old 11-29-2005, 09:57 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Question P0141 and P0443 Error codes?
Alright my car has been running shitty it's got the 6bolt in it so i wasn't suprised it had a cel, but these codes kinda confuse me.
P0141 Is the second o2 sensor (no suprise there)
P0443 is Evaporative Emission control system purge valve circuit malfunction.
Anyone know if this could be making my car run shitty? All the emissions bs is off (egr blocked and evap can gone)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 11-29-2005, 10:16 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
I wouldn't think either of those would have anything to do with your car running shitty. I've pulled both codes before on my car with no problems. P0141 is something screwed with your secondary 02 sensor and P0443 is just a hose loose off the back of the throttle body. But you said you got rid of the evap system so...but either way I'm not thinking it would make the car run shitty.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 11-29-2005, 10:20 PM
ez1286's Avatar
Re: P0141 and P0443 Error codes?
I didn't think so either but i've been looking around on tuners and it seem like a lot of people have similar problem with idle suge and bogging when they get this code.
I didn't take the evap crap off the previous owner did and by the looks of it they just blocked off the evap tube from the tank. I though it ws supposed to have a breather on it...I think i'll take the screw out and clear the ecu and see what happens.
Old 11-29-2005, 10:56 PM
ez1286's Avatar
Alright i took off the screw blocking the line that went to the evap canister and that fixed it!!I'm getting a breather for it tomorrow cause i don't want crap getting in there (or maybe i just steal aaron's)
Old 11-29-2005, 11:01 PM
Turbodog97's Avatar
Just a Neon
lol. It's funny how the craziest problems can be fixed so easily on these cars. I'm glad you fixed it
05 Srt4
97 Mx-5
Old 11-29-2005, 11:05 PM
ez1286's Avatar
Thanks, me too. Who would have thought something like that would make it run so shitty and bog down?
Old 11-29-2005, 11:25 PM
Turbodog97's Avatar
Just a Neon
Well doesn't the evap system have to do with fuel pressurization? If so I assume it was causing the fuel to be inadequate for ideal combustion. Just my though.
05 Srt4
97 Mx-5
MexRocket's Avatar
MexRocket MexRocket is offline
touch my car again we race for slips lol
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 11-29-2005, 11:47 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Plugging the tank vent line would cause vapor lock if the tank couldn't draw air in to replace the fuel being used. The second O2 sensor monitors catalytic converter efficiency. In other words, if the converter goes bad, the CEL will come on....
Old 11-30-2005, 12:54 AM
ez1286's Avatar
Re: Re: P0141 and P0443 Error codes?
Yeah i knew it wasn't supposed to be blocked, i'm just glad it's fixed, oh and e uh catalytic converter.. uh seems to have been "misplaced" lol.
Aaron: Slips now Randall/Rt. 62!!
Old 11-30-2005, 12:58 AM
My cat. has also been "relocated"...in the scrap pile. You know an O2 simulator from jegs or summit will fix the O2 sensor code..
Old 11-30-2005, 01:03 AM
ez1286's Avatar
Actually i'm not getting that code anymore either...strange
Old 11-30-2005, 01:09 PM
Yeah, my code came and went. According to the sensor, my ghost converter would work some of the time...
Old 11-30-2005, 03:50 PM
ez1286's Avatar
Goddamn it! I went to go to work today and got the same codes again!! After a few minutes it was bogging down really bad again. Also the egr solenoid, purge solenoid and the fuel pressure solenoid are all gone, I know they're not vital but they are all missing...
Old 11-30-2005, 06:20 PM
The fuel pressure solenoid is a MUST!!!!
