Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 11-29-2005, 09:52 PM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
240 noob, need advice
hey guys in pretty unfamiliar to the 240 scene, but ive plenty of knowledge of nissans, (i drive a 2005 spec v sentra) im looking ot pickup a 240sx for a project car, i will be needing it for track use, learning to drift (police training course with no walls, basicly a flat parking lot, im not going to crash it) and eventually showing it. I really like the s13 hatchback side and rear, but ive seen a front end conversion that i love, i think it was a s15 front, what are your opinions on the best looking 240? i will be looking for one with no motor, im going ot swap in a rb26 anyways and if im swapping the fronts, the front end doesnt need to look good or anything, as long as it isnt bent up or anything. also what kind of work is involved with swapping the rb26dett into each chassis, is it as simple as mounts or do you need driveshafts and tranny mounts as well? i would appreciate any help you guys may be able to give, i want plenty of research before i go buying things. thanks in advance
Old 11-29-2005, 10:03 PM
orestes's Avatar
orestes orestes is offline
yea driveshaft and the rb25 transmission and transm. mounts. you could also just get the RWD RB25DET, but whatever. and personally i dont like the S15 front, i like either modded popups (half open ones w/ diff. bulbs, or clear housing stationary ones like 300ZX) or the S13 Silvia front (square lights).
"I got that hustle in my genes like high blood pressure" -E-40
Old 11-29-2005, 10:27 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
Check out this thread, we went through alot of different possible conversions.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 11-29-2005, 10:28 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: 240 noob, need advice
You need the RB25DET transmission and oilpan, you'll need custom engine an dtranny mounts, custom downpipe, driveshaft, rad hoses, turbo piping, etc. It's a big job that's made for show, 99.9% of people will never even come close to use the full potential of that engine and will be better off with a KA or SR or CA.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 11-29-2005, 10:36 PM
i will admit that most of why this engine is being used is to say "skyline engine in this bish" i fully realise that the sr20det or even a ka-det could be more than enough, what are the major differences in the rb26 and rb25det's? which powerband is fatter, and which one is easier to swap? im fully flame ready, but flaming will do nothing for improving my knowledge, im trying to learn something here
Old 11-29-2005, 10:38 PM
would i need to swpa gauge clusters and tach's what is the redline of each engine and which is better for drifting, particular motor the 240 responds well to?
Old 11-29-2005, 10:39 PM
RB26 is twin turbo and has an extra .1 liter and has ITBs and has a 6speed tranny (R34) but it's AWD so you gotta use the RB25 tranny.
-Jonathan
Montreal, Canada
Old 11-29-2005, 11:36 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
the RB26 has ITB's? I never knew that, wierd...
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 12-02-2005, 03:38 AM
nissan_240sx nissan_240sx is offline
me either.
BTW good to be back , finally finished with my college course
Is it just me or does it seem like everyone is leaving?
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 12-02-2005, 11:20 PM
Skylindrftr Skylindrftr is offline
Send a message via AIM to Skylindrftr
Not really full itbs i think, or at least a little different that regular ones, they come in 3 parts with 2 throttle bodies per part...i think the primera with sr20 has similar thing except 2 of them...
Old 12-03-2005, 12:38 AM
TatII TatII is offline
no, the RB26 has 6 individual throttle bodies as in, it has 6 individual throttle bodies all hooked up to the intake manifold. if you look at it upclose, you can see the individual rocker arms pulling every single throttle plate open.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 12-03-2005, 09:41 AM
The difference between the RB26 ITBs and the ITBs on say an NA F20c is that the RB26 ones have a plenum around them, the Honda ones are usually atmospheric.
-Jonathan
Montreal, Canada
Old 12-03-2005, 12:23 PM
orestes's Avatar
so the Honda ones run like you see in picutres, no filter or anything just 4 holes?
Old 12-03-2005, 12:43 PM
Ya, the trumpets or whatever they're called.
-Jonathan
Montreal, Canada
Old 12-03-2005, 01:33 PM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
anywho...back on topic for this guy...its been said many times before...do something to the car that you would like...if you like the s13.5 conversion...do it (s15 from on s13 chassis) if you want to do a rb26 do it...it is alot of work. if your going to do any RB series swap i would recommend getting mckinney mounts and crossmember, to make the engine sit properly...there are alot of dissicusions no the RB swaps...just you the search function...good info to be found.
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
