Old 11-29-2005, 09:39 PM
knotter1995 knotter1995 is offline
engine
i have an 1995 Eagle Talon Esi 2.0 engine, i just recently put in a water pump in it, i checked the timing to make sure it was timed right , i even had a local shop make sure. ..but now the engine doesnt run good..it keeps wanting to die, unless i give it gas..
Old 11-30-2005, 12:01 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: engine
Has it done this ever since you changed the water pump? If so, the only thing you can do is retime the motor. you are probably off 1 tooth on one of the gears.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-30-2005, 01:27 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: engine
i'm guessing the timing is off...it has to be EXACT or the car will run pretty crappy. follow the guide in the chiltons manual, it's a pretty good one. and do it like it says, don't just go by the pictures and headlines
95 Talon TSI AWD
97 Eclipse GST
Old 11-30-2005, 10:49 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: engine
you may have also accidentally given yourself a vacuum leak when replacing the water pump.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
