Old 11-29-2005, 10:23 PM
MPe488 MPe488 is offline
First mods 98 A4 LS1
I don't have ANY money now, but as soon as I get some I still won't have much so I'm gonna try to keep stuff cheap as possible.
I was thinking-
Magnaflow or SLP Loudmouth catback
Dual cut outs behind headers
Lid & some kinda foam filter that the air flows through more easily
possibly gears
I kinda tossed out the idea of kook LTs and an X-pipe cause it's too much $$.
So, tell me what you think I should do differently... the only thing I really need besides best bang for buck is to keep my gas mileage or even improve it a bit. I can't afford new mods and more gas money, it's just not gonna happen... so I gotta restrcit myself there. Thats why the gears are probably a 'no,' I can't lose the highway mileage as it's gonna get a lot if highway miles in the next 7 years.
I'm not the most knowledgeable person on engine mods so I could use any help you guys can offer. Thanks ahead of time.
'98 Trans Am A4
Bone stock... no times
http://www.cardomain.com/ride/2186058
Old 11-29-2005, 10:51 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: First mods 98 A4 LS1
3500 stall.
Go with Magnaflow.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 11-30-2005, 01:37 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
less restrictive filter and free flowing exaust will help with the mpg, so those would deffinatley be your best place to start
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 11-30-2005, 06:44 PM
If I got cut-outs and a cat-back would I have to toss them if I decided to get LTs and true duals in a while? And what would be the difference in HP between the two set ups?
And won't the 3500 stall make it harder to drive and consume more gas? I think I need to get used to all the torque this car has first. My last had 100 ft-lbs, so I'm still on the learning curve.
Edit: I was also actually wondering about a ported TB and an ls6 intake. I don't know as much about those as I would like to- so, can I use a ported stock TB with an ls6 intake? Or does the ls6 intake package have it's own tb... (i'm clueless, I know.)
'98 Trans Am A4
Old 11-30-2005, 07:24 PM
Mr. Luos's Avatar
Firebird Guy
On the intakes....The LS6 intake is shaped exactly the same as the LS1 intake at the throttle body and the top.
The differences are inside and on the bottom. VERY good mod for 98-00 LS1 cars.
You will be using your stock throttle body. I recommend a ported TB and LS6 intake for lightly modded cars....don't need much more than that.
The stall will probably slip mileage down a little. Shouldn't be too bad though. The stall is the best mod you can do on the auto LS1 cars though. Gets you off the line SO much better.
I am not a big fan of cutouts. They are problematic. Carbon causing rust causing them to stick shut (electric ones) and the manual ones are a pain.
Car will sound great and pick up a little power over your average y-pipe and catback though.
I can see a good shop making sure your cutouts are re-useable once you get headers. They need welded up, then they would need cut and welded again once you get longtubes.
Don't put the cutouts right at the headers though unless you have a nice stall. You lose power down low running open like that. When I was running open headers I had some minor surging issues down low and it just plain out was slower. Not a ton slower....just didn't seem to have the kick it normally had...anywhere in the RPM's.
Stock'ish'
Old 11-30-2005, 09:40 PM
thanks for the help, but I still have tons of questions and I hope I'm not bothering anyone with them. heres a few-
how hard is it to swap out gears? I was thinking about throwing on 3.73s for awhile cause I drive city 95% of the time until I end high school, then maybe I'll swap back in the stock ones for highway mpgs.
And will a 3500 stall cause my rear end to need replacing anytime soon? Thats a major concern for me. In faact that the reason I didn't opt for the t-56. And will it hurt the tranny?
'98 Trans Am A4
Old 12-01-2005, 07:05 PM
Mr. Luos's Avatar
Firebird Guy
Not sure about the gear swap. I imagine it wouldn't be too bad with the right tools, although I don't know what those are.
Stall shouldn't hurt anything. The nice thing about the auto is that it preloads the rear....much less likely to break that way.
Stock'ish'
Old 12-01-2005, 10:29 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Re: First mods 98 A4 LS1
Well if the car is mostly stock u don't need that mush stall speed i would go with 1500-2000 and don't try to put in gears yourself if u don't know how u will trash the rearend get a shop 2 do it 4 u.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 12-05-2005, 07:29 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
With Lous on this one. I have 3.73's and gas mileage didnt really change much on the highway but it did go down around town. I would go with the stall first as it will only effect ur gasmileage in town under about 45 MPH after that it will be like driving normal. Remeber tho whether u get gears or a stall to get any use out of either one u will need stickier tires. Unless u really know what ur doing dont do the gear swap ur self or u will regret it. I would go with a hooker cat-back since i think they get a better sound and are cheaper. Some pacesetter LT's would work great too u can get them cheap along with the TSP y-pipe from www.texas-speed.com. I would do exhaust, intake, light suspension(tires, SFC's) since it wont be a track monster then stall and gears. If u want most effective first then stall and tires.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 12-15-2005, 02:15 PM
viperh viperh is offline
Send a message via AIM to viperh Send a message via Yahoo to viperh
Get sub-frame connectors.. Night and Day diffrence in handling. Also if your t-tops are leaking it'll stop that.. about 400 bucks from UMI performance.
Old 12-15-2005, 02:34 PM
Mr. Luos's Avatar
Firebird Guy
If you pay $400 for subframe connectors, you paid $150 too much.
Check me
Stock'ish'
Old 12-15-2005, 03:08 PM
Check me
I was over estimating. I dont remember the exact cost.
Old 12-15-2005, 05:57 PM
z28 boy's Avatar
Actually u can get subframe connectors for less than that u can get them for 150 even.
2000 Z28 A4:
Old 12-15-2005, 06:11 PM
Mr. Luos's Avatar
Firebird Guy
Agreed.
But I like the diamond ones.
Stock'ish'
