| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
dsm link
when u go to dsmlink.com it has something you can download, but then it says by dsm link for like 500$, what is the thing u can download for free? also, does dsmlink come with wires you hook up to the ecu, and is dsmlink important in ur views?
Chris Winchell 95 GSX 12.5 ET with a 1.9 60' at 115 mph Actually have traction this year 90 TSI <Project Acer> 2.0L, 2400 lbs AWD, t-67 goodness |
Re: dsm link
dsmlink is the best....u basically DL the program and u can play around with it...they socket ur ecu and i assume u get the wires.
95 Eclipse GS-T 6 bolt built block - shooting for 450 hp..very doable Currently: A lot, check progression thread - updated 3/27/10 Estimated completion date: Soon lol |
yes, it is highly recommended by everyone that uses it.
do a search on this site
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Re: dsm link
I've been a dsmlink user for almost a year now, and I must say it's the BEST mod I've done to my car. It's extremely user-friendly and makes tuning a breeze. Once you buy dsmlink you get access to the dsmlink forums that provide some of the best and most accurate information not only about tuning, but these cars in general. No bullshit on those forums either. Tom and Dave (dsmlink creators) visit those forums almost daily and help with any questions, ask for suggestions and things people want in upcoming versions of dsmlink, and also keep you updated with new things that dsmlink will be offering.
I could go on for a while about all the badass features that dsmlink has to offer, but their website explains most of it. I HIGHLY recommend dsmlink to anyone that is looking for a nice engine management/tuning device. And yes, the program you download on the website is just the laptop software portion of dsmlink so you can goof around with it and see some of the features. When you purchase dsmlink, you get their chip (which they can install for you if you send them your eprom ecu), the cables needed to hook your laptop up to the diagnostic port in your car, and a cd with the dsmlink program on it (same one from the website).
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
Re: dsm link
Not to jack this thread, but wheres a good starting point to change on your car when using dsmlink, ill be getting it in under a month and i want to start tuning ASAP lol
Re: Re: dsm link
Most people say once you start running anything over 550's that you should have dsmlink to tune. I am going to get it as soon as possible.
1991 GSX 2.3 Stroker |
Re: dsm link
That will be the next big thing i buy for my gsx, I don't think anyone has ever spoken bad about the all mighty DSMLINK.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Re: dsm link
There really is nothing bad to say. IF you have any problems or new ideas Tom and Dave incorporate them very quickly. Seems like a new client side software version comes out every month... Free of course
Typically the starting point is to get AFR to normal levels, like 10.5-11:1 for pump gas. Timing can be added in until you get knock, but this is a sensitive subject. On high horsepower motors I tend to stick with the stock timing values for the most part, making slight changes to the shape of the curve to suit the setup and airflow characteristics. The trick is to get into it gradually, so the learning curve doesn't cost you a motor. Start with small changes, note the effect they had, and as always keep reading up (especially on the DSMlink forums). The good thing about the DSMlink forums is that there is such a high percentage of experienced and knowledgable DSMers there, misinformation doesn't last 10 minutes. You can place a relatively high level of trust in anything you read there.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: Re: dsm link
DSM geek |
Re: dsm link
careful with making a boost leak man. even small unnoticable leaks can overspin your turbo do its death very quickly, imagine what a leak you setup can do. i wouldn't risk it.
now - 2000 civic soon - 2002 is300
Re: dsm link
exsesivly yeah, 1 or 2 pulls shouldn't hurt anything.
DSM geek |
Re: dsm link
making you turbo spin twice as fast to make the same boost WILL cause harm.
Re: dsm link
were not talking about a FPred here, I still have a t-25!
DSM geek |
Re: dsm link
how do you think i blew my 14b... didnt take much acouple weeks and maybe a handfull of pulls ,then it was gone. all becasue of a boost leak.
on a side note, rumor was that DSMlink V3 was going to have a MAFt incorporated into it.....not sure if this is ture but as soon as that happens , hello GM MAF!
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
Re: dsm link
I've been following up on the Major enrichment thread on the forum. Thats going to put Fullthrottle out of business!
DSM geek |
