Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 11-29-2005, 06:42 PM
crzylttldiamonds crzylttldiamonds is offline
Send a message via AIM to crzylttldiamonds Send a message via Yahoo to crzylttldiamonds
Question transmission problems...
i have a 91 lebaron and a was having transmission problems. typically i needed to get things fixed quickly so i just added trans. fluid. since then the gears slip. would a flush out be a fix? or would there be more to it than that?
Old 11-29-2005, 11:23 PM
94LebConv3La604 94LebConv3La604 is offline
What type fluid did you put in and how long were you running it like that for?
Old 12-14-2005, 10:47 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
Re: transmission problems...
yeah, what fluid did you use and no, don't do a flush it makes things worse. Did you use dextron III or atf+3, if you used dextron III then its time for a rebuild or another tranny.
Justin
