Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-29-2005, 06:02 PM
jenc1121 jenc1121 is offline
Unhappy Exhaust System-failed smog test
I failed my smog test b/c of a broken flex pipe. The mechanic is trying to charge me an arm and a leg. I was wondering how difficult this procedure is. We found a part and are pretty good with cars. Is this a huge pain or something we could do our selves?
Old 11-29-2005, 06:09 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Exhaust System-failed smog test
The flex pipe is kinda hard to change. You have to take off the downpipe and disconnect it from the cat. Also will be a bitch from the rust. I would suggest (if your looking to mod) replace the whole exhaust. However, this does cost, and it's not worth it at times. Check around for prices. An exhaust shop should not charge too much for it.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-29-2005, 06:15 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Also if you have access to an impact gun/drill it will make those rusted bolts come out pretty easy.
1991 GSX 2.3 Stroker
Old 11-29-2005, 06:30 PM
Re: Re: Exhaust System-failed smog test
We have pretty good tools, the problem is funds are very low. The mechanic already charged an arm and leg for the diagnostic, plus the smog test. We just need to know if this is something we can do on our own, without totally screwing our selves! Does anyone know the best way to go about changing the flex pipe? We also need to change the cad. converter, but I heard that is pretty easy.
Old 11-29-2005, 07:01 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
if you need to change both then do them at the same time. you'll have to take off all the exhaust from the downpipe till after the cat. just soak the rusted bolts with some PB Blaster the night before you work on it and then about 5 mins before your gonna work on it and they should come out pretty easy. it's not that tough of a job, the toughest part is getting the rusted bolts loose if they try and fight you.
95 Talon TSI AWD
97 Eclipse GST
