Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 11-29-2005, 12:51 PM
mrgull mrgull is offline
headlight motor spinning
My passenger side headlight goes up and down properly when the switch is turned on and off however that knob on top of the motor continues spinning whether the light is sp or down. What gives?
Old 11-30-2005, 07:18 AM
Old Lar's Avatar
Old Lar Old Lar is offline
Re: headlight motor spinning
What year car? In the 87 & 88 the internal bushings breakdown. The earlier years have a different headlight motor. www.rodneydickman.com sells rebuild kits for those problem motors. For the 87 & 88 the cost is $10 and the first one may take you an hour for the rebuild.
Typical Fiero related headlight problem.
Old 11-30-2005, 02:53 PM
Re: Re: headlight motor spinning
The car is a 1984 2m4 SE Auto
Old 11-30-2005, 08:40 PM
Old Lar's Avatar
Rodney still has overhaul kits for the 84 Fiero. My three Fieros are the 87 & 88 variety. The 84 kits can be done, but I've had no experience on them.
Old 12-16-2005, 10:33 PM
coop8267's Avatar
coop8267 coop8267 is offline
Its the delrin bushing on the big plastic gear inside the headlight motor. They pretty much turn into sand. I filled in the space with some high strength hot glue, problem solved. I also added a headlight motor bypass switch so I can leave them up when I will be getting in and out of the car a lot.
